11-22-2013 10:08 PM
Hey guys I got some wired problem with my canon 60d since 2 weeks...........
My LCD display automatically get inverted after every 2 to 6 seconds during the shooting or rest of the timings... Like when m changing setting in menu display get inverted and when in screen n menu mood....
Means any time it gets invert n than become OK. Its repeating again n again so I can't do my work with it. Please Help
08-12-2016 11:24 AM
If it's the sensor that's going nuts, I would try the following as the work-around.
1. disable the auto-rotate feature in the menu
2. use the manual rotate to rotate the picture so it's right side up.
08-12-2016 11:44 AM
Thanks for the advice. I have already done that a couple of times but the image displaying upside down is not realy a problem. It is the menu (especially the Quick Menu) that displays upside down when the screen is facing out and folded back (you have to rotate it to do that) as there is no way I can get that to display upright. My 60D was bought late 2010 already and I don't want to spend a lot of money on it at this stage. Apart from trying to fix it myself as already suggested I suppose I will just have to live with it like that untill it finaly gives in completely.
08-12-2016 06:04 PM
Exactly, the menu issue... Well I got it fixed by the canon tech support...it is not cheap. They changed the all LCD screen actually. It made the trick for sure. It does feel like it is a new camera...
08-12-2016 06:07 PM
Ah ! too bad your post is here after I got the camera fixed....
Oh well... it does look almost new now....
08-12-2016 08:54 PM - edited 08-12-2016 08:55 PM
Too bad indeed!
Just out of curiosity, how much did you pay for the repair and in which country/city?
Thanks!
08-14-2016 11:48 AM
I looked at the links, you got to be kidding, i would never suggest someone take the camera apart if they had no such experiance. I am a trained Techniction in a simmilar field and have attempted to repair digital cameras and never had any sucsess. Kidos to yo if you werw susessful.
08-14-2016 09:34 PM
thanks! actually it wasn't my first time dealing with really sensitive equipment, i have a background of ten years working with electronics, so that helps a lot!
08-14-2016 09:45 PM
11-02-2017 12:28 PM - last edited on 11-02-2017 12:31 PM by John_B
@fernandofry wrote:Hello Guys! I had the same problem with my 60D for a while and I have just figured how to fix it.
There is this sensor that gets loose and doesn't do its job. I put a little piece of paper against it to make some pressure and take it back to the correct position and it worked just fine!
You can see how to reach the sensor in the links below, you only need to take 8 screws out, it's super easy.
**Links removed per forum guidelines**
11-03-2017 01:23 PM
Hey! I'm sorry but I didn't take pictures by the time I fixed the problem and I no longer have the camera.
I remember it took me a while to figure that the problem was caused by the loose sensor, it was a trial and error processes, I don't recall 100% but I think I put the paper between the sensor and the spot it is fixed so it would stay a little further.
Sorry for not being very helpful, but I hope you figure how to fix, you got to be patient.
