Camera won't power on
denmarks
Hello,
I have a few 5dsrs that I use in aircraft...which vibrates a fair amount. On my last trip, one stopped powering on. I switched batteries, connected it ot an AC adapter...nothing. I was planning on sending it in for repair but it's turning on now. I'm a little concerned that if I send it in and it's working normally, the problem won't get found...though I would hope the technicians would look at it as if it was not powering up. Is this an intermittant problem others have had?
Thanks.
ebiggs1
Send it to Canon and explain the problem. Either they will find something or they won't but they will check it out totally.  It is your only option if you want to be able to rely on it.
EOS 1DX and many lenses.
4 REPLIES 4
Waddizzle
@denmarks wrote:
Hello,
Thanks.
There are sensors on the doors to the memory card and battery compartments, which can prevent cameras from powering up.
ebiggs1
Thanks, yes could be a malfunction in one of those sensors...I'll try opening and closing a few times and see if I can get the problem to repeat...
Thanks, I will send it in.
Friends and Family
