Camera screen won’t turn on
Earth
Hi!
I have a canon EOS Rebel T5. I can focus my camera on objects and take the picture, but the screen will not turn on. I can't see the picture I took or the settings I'm on. Do you know what's wrong? Can you help me?
Earth
I figured it out, I had to take the SIM card out and put it back in. It didn't immediately come back on, but after I turned the knob for the settings around a little bit came back on.
3 REPLIES 3
Earth
Are you using a full-sized, brand name SD card, or are you using a micro SD card with an adapter?
Robot Frustrated
If your Camera is still showing a black screen after a hard reset, then the problem is caused by a hardware related issue. This means that the camera application has malfunctioned or the lens is broken. If this is the case, take your smartphone for repair.
myccpay account
Friends and Family
