10-18-2021 04:37 PM
Hi!
I have a canon EOS Rebel T5. I can focus my camera on objects and take the picture, but the screen will not turn on. I can't see the picture I took or the settings I'm on. Do you know what's wrong? Can you help me?
10-18-2021 04:43 PM
I figured it out, I had to take the SIM card out and put it back in. It didn't immediately come back on, but after I turned the knob for the settings around a little bit came back on.
10-18-2021 04:43 PM
10-19-2021 03:47 PM
Are you using a full-sized, brand name SD card, or are you using a micro SD card with an adapter?
11-26-2021 11:09 PM - edited 11-29-2021 04:19 AM
If your Camera is still showing a black screen after a hard reset, then the problem is caused by a hardware related issue. This means that the camera application has malfunctioned or the lens is broken. If this is the case, take your smartphone for repair.
