03-19-2020 08:42 PM
I am having a problem with my canon sl2 and andeer extension tubes with autofocus support. Whenever I change lenses with the extension tube still attached to the camera, the camera will not power on after the lens change unless I take out the battery, and put it back in.
03-20-2020 12:54 AM - edited 03-20-2020 01:06 AM
03-20-2020 03:37 AM
@Nsanti wrote:I am having a problem with my canon sl2 and andeer extension tubes with autofocus support. Whenever I change lenses with the extension tube still attached to the camera, the camera will not power on after the lens change unless I take out the battery, and put it back in.
Review the instructions for the extension tubes. I think you should attach them to the lens, and then attach the combination to the camera. You should not mount the tube on the camera, and then mount the lens to the tube.
03-20-2020 10:33 AM
Oh, yeah. The camera should be turned off when you mount and dismount any lens, especially when using an adapter.
03-20-2020 10:41 AM
"... the camera will not power on after the lens change unless I take out the battery, and put it back in."
This is a red flag to me. I would buy some real Canon tubes and not use those anymore. The camera doesn't like them.
03-20-2020 10:44 AM
after some more testing I discovered it really doesn't matter if the tube is connected to the camera or the lens. after powering off the camera and changing to a lens with the tube attached it won't power on unless I pull out and put back in the battery. I've come to the conclusion that the use of $15 tubes is not worth it to possibly damage my $400 camera.
does anyone think I caused damage to the camera by trying this. It seems to function fine now.
03-20-2020 10:47 AM
"The camera should be turned off when you mount and dismount any lens,..."
You know I used to think this was true but I don't anymore. The last pin to make contact is the power pin. The first one to break contact is the power pin. Once the lens is turned a tiny amount, power to the lens has been removed. Now there may be some reason inside the camera that doesn't like being on when changing lenses but I can't imagine what or why?
03-20-2020 10:48 AM
I'd say from the odd symptoms you have described the potential to cause damage to your camera is real. You should quit while you're ahead and toss your tubes!
03-20-2020 10:49 AM
"does anyone think I caused damage to the camera by trying this...."
It can't be good because Canon tubes don't do that. It may not damage the camera but like you said $15 vs $400. Why risk it?
03-20-2020 11:07 AM
It is still good practice. often when a pin connects like that there is "contact bounce" so that the lens would recieve and lose power several times in a short period of time. That can cause spikes or just confuse the computer in the lens.
