09-27-2018 11:55 PM
09-28-2018 01:55 AM
Is this something new or has it always happened?
What exposure mode are you in?
Have you tried to reset the camera?
09-28-2018 08:47 AM
09-28-2018 10:09 AM
@Hamdrex wrote:
I bought the camera recently second-handed and I just realized it had this problem. I have tried this with every mode on the camera and it still happens even when set to AUTO. I already did a reset, updated the firmware all to no avail. This is very frustrating. At first I thought I had messed some setting without even knowing about it, but when I tried in AUTO and still got two waaay different pictures through the View Finder and the LCD screen I knew I had a problem. Please help!
What lens are you using?
09-28-2018 10:19 AM
As far as I know, the exposure is set the same in viewfinder and live view. i.e., the sensor is not used for exposure. I don't know why they would be different. It could be something blocks the exposure chip when the mirror is down. You have done all the right things, it is probably time to take it in for service.
09-28-2018 10:23 AM
09-28-2018 04:50 PM
Try looking at the EXIF data from a handful of images and see which metering mode is in effect for shots that are properly exposed as well some that are overexposed. Is the metering mode changing between Average, Evaluative, Spot Metering, etc.? Are their unexpected variations in the ISO ratings?
As Wadizzle asked, what type and brand of lens are you using?
