07-24-2019 10:23 PM
07-25-2019 03:07 AM
Hi rql49,
That definitely sounds like odd behavior in the auto mode, the first thing I would look into is the lens. Do you have a second lens you can try to see if the problem happens across all lenses? If it doesn't happen on other lenses you may want to look into repair or upgrading the lens.
07-25-2019 10:52 AM
"I have to adjust the _____________ to have it under exposed by 2 or 3 stops."
You have to adjust, what exactly? Their are two places to reset the T4i, you did both? You need to try a different lens, too.
07-25-2019 11:33 AM
07-25-2019 03:26 PM
"... What are the 2 places..."
There is 'clear all settings' and 'clear all custom settings'. You need to do both.
"The exposures...."
Yeah, I gathered that but how did you change the exposure?
07-25-2019 12:01 PM
07-25-2019 03:28 PM
"I switched the lenses and still having the same issues."
OK now you know it isn't the lenses and probably it is the camera. Perhaps, though, it is you?
07-25-2019 03:35 PM
07-25-2019 03:40 PM
"...ABE setting"
Yeah, that isn't the place to do exposure settings.
Auto Exposure Bracketing shooting is where you can set your camera so that the shutter speed and aperture value are changed automatically to capture three successive shots with different exposure (bracketing) settings. Say a +/-2-stops in 1/3-stop increments for example.
You need to put that back to zero. If you fully reset your camera it went back to zero. So if you still have it active, you didi not reset the camera.
07-25-2019 03:42 PM
Here is what you need to do.
Nice sunny day. Go outside put the camera on "P" mode. Set the ISO to 200 fixed, no auto ISO. WB set to daylight. Take a few shots. If it works, it works and the problem is elsewhere, like AEB.
