Best Canon Camera for Photography
rudra00
I've had my current DSLR for over 5 years and it's time for an upgrade! I have the Canon Rebel t3i and have used this primarily for photography (portraits, engagement, maternity). I'd like to hear from Canon users on the camera they use for similar photography sessions. The most I'd be willing to spend is $1,500 (but if you can make a good case for a more expensive camera, I'm willing to listen 😂). Any photos to showcase the quality would be awesome. Thanks so much in advance!
4 REPLIES 4
If you plan to buy a new body now...  buy mirrorless.
It sounds like you will be a candidate for the upcoming R7.
Canon EOS R7 (Price & Release Date) - Canon Rumors CO
Unless you are going to replace your existing glass and go FF, you'll have to wait for it at your $1500 price point.
Tronhard
VIP
VIP
Given you have a budget of $1,500, the projected R7, when it finally becomes available (as opposed to announced) and being a prosumer unit, will not be cheap.
So, if that is too rich for your tastes, given that you are shooting people singly or in groups, you could likely pick up an RP very cheaply.  A crop sensor body has disadvantages at the wider focal range end, but advantages at the telephoto end.  The RP is a FF unit, so the ability to get shallow DoF with fast lenses will be a benefit.  Given you are currently using a crop sensor body, if you are using EF-S lenses, you can use them with the RP via an adapter, but that will drastically reduce the MP count by a factor of 2.56: so that would give you a MP count reduced from 26MP to about 10MP.  It would be helpful to indicate what kinds of images you produce - i.e. digital, small prints, large detailed images. Depending upon what you are producing, that might be fine.
Another alternative is to go for one of the last APS-C DSLRs - you could likely pick one up refurbished within your budget.  The 90D has a good 34MP sensor, and a lot of upgrades from your current body.  However, the higher resolution will put pressure on your older or cheaper lenses (worth listing those, please).
cheers, TREVOR
rs-eos
More information is needed.  Do you wish to keep your existing lenses? If so, what do you have?   Keep in mind too that you may need lens adapters with the new camera.
You can always visit Canon's own Product Page, set the "Product Series" filter to "Mirrorless Cameras" and set the price slider to be at a maximum of $1,500.   When I do this, it shows many EOS M-series cameras/kits (e.g. M50) along with the EOS RP.
Ricky
ebiggs1
If all I wanted to do was to upgrade your camera and leave the rest pretty much as is, I would buy the Canon 90D.
A further enhancement to a 90D might be the Sigma 18-35mm f/1.8 DC HSM Art Lens. This combo would not be embarrassed even by the top of the line camera/lens and mirrorless camera/lens combo models costing many time more. Keeping in mind you said, "... primarily for photography (portraits, engagement, maternity."
If you are looking at the future the way to go is mirrorless for sure. But checkout the 90D and that fast Siggy lens.
