03-29-2019 07:55 PM - edited 03-29-2019 10:16 PM
The Lions Club to which I belong would like me to video tape our speakers. I am a long time still photographer, but have zero video knowledge. I am going to use an 80D, 24-70 f2.8, and Road mic. The meeting room holds about 100 people so it is not very large. I suspect the front row of lights will be off for the projector screen.I am thinking manual focus with maybe f8 for DOF.
Question, please give me a starting set of camera video settings with which to practice.
Can you please recommend a book, online tutorial/video that can get me up to spped rather quickly.
Thank you.
Mike
03-31-2019 10:30 AM
@MikeV2013 wrote:
Thank you for the videos. I can do the exposure/DOF settings pretty much in my head for stills with my regular cameras. Just not sure about frame rates, etc. for video. I took a practice shoot and am headed to Photoshop to see what I can do - learn Premier if I must. I just want to video a speaker not become a videographer. I am hoping the 24-70 f2.8 helps with the light issue.
I think any quality lens would be just fine for static shots. It is when subjects begin to move about the frame, or when you begin to move the camera, is when things begin to get really complicated, really fast. Set up a tripod, and let it run. Do not forget about the 30 minute time limits. You can also expect the camera to overheat after extended use in video mode.
I suggest using 24 fps frame rate, and a 1/50 sec shutter speed, which is equivalent to a 180 degree shutter angle. This will give your video a ”cinema” look. Faster frame rates will allow you to record in brighter light without the use of an ND filter.
Using higher frame rates will, of course, need faster shutter speeds. But, the faster frame rates will not only create MUCH larger files for a given recording time, but the resulting videos may begin to take on a “video tape” look, due to a loss of motion blur in the individual frames.
Take a few stills of the venue, so that you can get an idea of what the light is like. I have no idea what it is, so I can only offer rules of thumb, guidelines, and strategies.
Computing DOF in your head is pretty impressive. I regularly refer to the table when I know light and DOF will be critical. Given enough practice, I suppose that i could memorize enough of it with enough experience with the same lenses.
Canon has Movie Software that you can use, too. Not as good as PSE, but it is free.
03-31-2019 12:49 PM
05-23-2019 04:27 PM
You seem to know your stuff. Maybe you could help me. I am a video prodcuer that is not often behind a camera. I am working on getting up to speed.
I have an 80D and a Ninja V for recording and monitoring. Is there a way to turn of the red record light so it does not appear in the Ninja record.
I am baffled and been looking for days
05-23-2019 09:10 PM
@severin1 wrote:You seem to know your stuff. Maybe you could help me. I am a video prodcuer that is not often behind a camera. I am working on getting up to speed.
Which device is generating the “red record light”, the 80D camera or the Ninja recorder?
I no longer have an 80D to play with. I gave them [3] away to friends and family. It is a great camera. After I gave one away, i figured that I had better keep giving away the same model. But, I digress.
If I could test it, then I would. But, I do not know if the 80D has a “clean” HDMI output in video mode. However, if you are using an external recorder, then you really do not need to put the camera into video mode. Live View may have a clean output, too.
05-31-2019 09:15 AM
