02-19-2016 07:28 PM
This camera worked fine for 6 months and all of a sudden it wont write to either card. I have tried 2 cf cards. I have also noticed buffering taking longer than usual. Can anyone help?
02-19-2016 07:44 PM
peep into your camera memory card slot base and see if there are pins bent. This is only one of the possibilities.
02-22-2016 11:45 PM - edited 02-22-2016 11:49 PM
Have you tried SD card ? Same problem ?
When you said buffering takes longer than usual, are you using the same cards you were using or have you set the image quality to Raw +L whilst using a slow card ?
