11-30-2014 08:55 PM - edited 11-30-2014 09:12 PM
I've tried to connect via the supplied cable my 7D2 to my MacBookPro. I have a 2009 13' MBP with USB2 ports. My softwares for use with the 7D2 are up to date (EOS utility, Lightroom).
I shoot tethered all the time with my 5D3 on that computer using those software without issues.
When I connect the 7D2, EOS Utility simply doesn't see it. When attempting to tether shoot with Lr, the camera attempts to connect but fails, the connection is just blinking between connected / not connected... and doesn't settle.
I've tested the camera and cable on an other computer (PC), no issues.
Anyone else having trouble like this?
12-08-2014 04:02 AM
Problem solved with EOS Utilities. The issue with Lightroom is that the latest version doesn't support tethered shoot with the 7D2... so will have to wait for that.
12-01-2014 09:18 PM
Is your software up to date on that computer? Fay
12-01-2014 09:24 PM
Yes Fay, as stated in my original post the software used to test the camera is up to date.
12-01-2014 09:53 PM
Oops. Sorry.
12-03-2014 06:35 AM
FredJ,
Are there any devices connected to your MacBook other than the camera, like a printer or an external drive? Is the MacBook connected to AC power?
12-03-2014 09:55 AM
Hello Mike,
I've tested again this morning with Lightroom, here's what I did:
1. No other devices connected, 7D2 using battery
2. USB drive connected, 7D2 using battery
3. No other devices connected, 7D2 using Canon ACK-E6
4. USB drive connected, 7D2 using Canon ACK-E6
The connection doesn't settle in any case. See below a small unedited clip showing the behaviour of the camera and Lr.
https://dl.dropboxusercontent.com/u/28457054/7D2%20tethered%20test.m4v
For EOS Utility, when opened and waiting for a camera to connect, it simply does not react to the camera when I turn it on.
12-03-2014 10:13 AM
I forgot, yes, the MacBookPro was on AC power. 😉
12-08-2014 04:02 AM
