6D does not connect on second wifi
sirugo
I managed to connect my 6D to my laptop over my girlfriend's wifi the other day. When I came home I wanted to do the same on my own wifi.
Menu -> Wi-Fi function
There I only have Exit/Confirm set/Error details
to choose from
I choose Confirm set and I can see the Basic settings and the name of my girlfriend's wifi, the name of my laptop and her SSID.
But these settings are only for the connection I established in her apartment.
Now I want to do the same here at home. But I can't find a way to add another connection or to change the one I have.
Help!
6 REPLIES 6
Skirball
If you go through "connect to laptop" again it doesn't offer you the option to create another connection?
But that never shows up!
Or which is the first menu choice I should make to get that option?
Beneath the Wifi Enable/Disable line there should be a WiFi Functions line.  IF you click that it takes you to the screen with all the Icons, right?
It should.
But that does not happen.
I get the "Exit", "Confirm set" and "Error report"
No screen with icons.
But I remember that screen from the moment when I set that first wifi connection.
The first connection is registered but I cannot delete it or change it.
And I cannot find a way to add another connection.
It worked now.
I didn't realize that I should press Exit to make it work.
"Exit" didn't seem to be the proper button, so I never tried until now.
Friends and Family
