12-25-2012 03:38 PM - edited 12-25-2012 11:50 PM
I almost hope the camera is faulty, but not really. I can't get the quality to change to RAW. The outer wheel should change the RAW settings, but it and the smaller wheel change the JPEG options. Any help would be appreciated.
12-26-2012 12:51 AM
I don't have 6D yet but should be similar to my 5D. On info screen scroll down to quality with joystick (Central wheel on 6D). Push on the "Set" bottom to highlight (Choose) Quality first, then turn the small wheel near shutter release to get to the type of RAW you need.
12-26-2012 12:09 AM
12-26-2012 12:16 AM
Thank you for your suggestion. I have it in M and just tried the others, but no change. I feel like an idiot. I'll call them tomorrow. Thank you again!
12-26-2012 12:51 AM
12-26-2012 01:06 AM
Samsen - THANK YOU!! You are responsible for the good night's sleep I will get tonight (this morning). I really appreciate you taking the time to help me.
06-23-2013 09:02 AM
I can't believe I was shooting in JPG for over 1 week before I noticed in LR. All of a sudden I saw jpg at the end of images I hadn't even worked on. Thanks for your answer. Wow, the images were coming out very colorful and I wasn't used to this. I thought it was the new camera and lenses. 🙂
08-15-2013 12:59 AM
We had the same problem at first, too. Turns out that the wheel that controls the RAW quality setting is the one on the top of the camera (the "Main Dial"), not the "outer wheel" on the rear of the camera (the "Quick Control Dial").
10-17-2013 02:02 AM
I tried the wheel by the shutter as well as the main wheel with the setting on manual and could not get to the RAW toggle. Does anyone have additional suggestions for what might be the problem? I have the Wifi setting off, as the Canon manual suggests also.
Thanks in advance for any help
04-10-2015 05:35 PM - edited 04-10-2015 05:35 PM
I disabled HDR and onl then I could turn on raw.
03-02-2016 04:38 PM - edited 03-02-2016 04:39 PM
mbirk I looked EVERYWHERE to solve this problem and your answer was the only one anywhere on the interent that helped me lol THANK YOU!!
