11-16-2012 09:35 AM - edited 02-05-2013 06:40 PM
Hello All,
While I am new on these forums I have been on the Canon Rumors Forums for a few years now,
I really wanted to bring this too the attention of you and Canon as it is simply a highly important problem, those of you that don't know, the 5D3 suffers serious focus locking issues when a Canon speedite is attached in Low light, the AF assist beam causes lag with the AF from the 5D3, this makes it virtually impossible to achieve focus in low light when the speedlite is attached, I wanted to bring the topic to this forum, so I have pasted a link to all the discussion we have already had about this problem at Canon Rumors.com - see below
http://www.canonrumors.com/forum/index.php?topic=10275.0
Please help in letting Canon know this is a very serious problem and effects the cameras performance in most working environments when a speedlite is attached and working in low light, conferences, nightclub work, weddings etc, and can stop the photographer completing the job or task.
Regards
Louis
12-14-2012 04:22 AM
Hi Mike-
I can confirm there is something strange going on with the 5Diii in low light.
I posted 2 targets, Target 1 at 20 feet (evenly exposed at 1.60, f2.8 ISO 400- I believe close to EV7), Target 2 at 4 feet underexposed 7 Stops on the same settings, and then focused back and forth 30 times with 3 different Canon bodies using a Canon 600 Ex Speedlite AF for focus assist.
Camera/Total Time through 30 focus locks (Target 1 is always faster BTW)
Canon 5Dii - 45 seconds
Canon 6D - 52 seconds
Canon 5Diii - 70 seconds
1. Im using a 24-70 2.8 L II lens, all shots were taken at 70mm
2. The underexposed Target 2 was 4 feet away, this is where it struggles.
3. Center Focus square
Michael
12-14-2012 04:32 AM - edited 12-14-2012 04:33 AM
I should probably add a note about why I am going back and forth between the 2 differnent targets at different distances; Target 1 serves mainly to defocus. If im just aiming at target 2 and focusing over and over, its not a good measurement of the cameras ability to get that initial focus.
Another point is that the average focus times for each shot work out to:
5Dii - 1.5s
6D - 1.7s
5Diii- 2.33s
But this is not what is happening. The focus lock on Target 1 (in good light) is always very quick, almost instantaneous.
Focusing on Target 2 is taking longer than these average times. In fact, most of the time is spent on Target 2.
Unless I had someone watching me with a stop watch it would be hard to know exactly (maybe we have to just video tape this whole event).
But I would say the times are closer to:
5Dii - 2.2s
6D- 2.5s
5Diii - 3.5s
I was planning on doing some more tests this weekend. If you guys want me to try something specific let me know. Ive gotten some good recommendations.
M
PS- If it makes anyone feel better, the Nikon D600 cannot focus at all on target 2 without it's focus light on. 😉
12-14-2012 11:42 AM
The use of 2 targets to "de-focus" or "refocus" or whatever is smart. Perhaps you should test it using 2 targets that are both in dim light, rather than one in dim & one in bright? I'd hate to let Canon off too easy by making the test too easy.
12-14-2012 04:24 PM
Mike? Where did you go? Anyone else from Canon out there? Anyone at all?
Miii-iiii-ii-iii-iii-ke!
Can anyone at Canon give us any information at all on whether this is being looked at? Or what is the nature of the problem? Will it be addressed in the firmware update? Even if the information is that you still don't know anything, but that you are listening?
Any Canon person?
Mii-iii-iii-ke??????
11-28-2012 08:07 AM
Im having the same problems. But i dont think its just an AF beam issue, my 5d3 is slow to focus in any low light situation.
As a festival/nightclub photographer, i bought the 5d3 to take advantage of the high iso along with the new af system. The 5d3 failed me. Im having to go back to the 5d2 which is amazing at focusing with low light and also using the af assist beams (ste2 transmitter and 580ii).
Im using it with these lenses
14mm 2.8L
15mm fisheye 2.8
35mm 1.4L
50mm 1.2L
85mm 1.2L
Ive experimented with the af settings in the menu and also with different focus points but still no joy.
This is extremely frustrating and totally unacceptable. How can Canon get something this important so wrong?
Marc
11-28-2012 12:55 PM
Canon 1DX have same problam
slower focus in dark with 600EX-RT
35MM F1.4
50MM F1.2
85MM F1.8
all my lens are same problem
i think its new focus system bugs
compare with my 1D mark IV
it's very slower on focus
please fix the problam quickly ^^
11-28-2012 04:34 PM
I would like to add my 2 cents also. I have shot for 6 years with the Canon full frame bodies...first the orig. 5d, then two of
the Mark2's....just got a mark3 and I noticed right away at a reception...as I was doing group photos using the center focus
spot in one shot mode....there was a distinct delay that is definitely not there in mk2....this is with the AF assist in indoor
lighting that is not even that dark. Never had a problem with the Mk2 and center spot with a flash attach...it is instant and I
can even follow action in a fairly dim room with it. The mark 3 is def better in AI servo mode, which is great...but I need that
one shot ability for portrait and reception shooting. I am using the 600 rt flashes with my cameras.
The one thing I can say is when the mk3 does focus fully...it always nails it accurately which is something the mk2 sometimes slipped up on.
11-28-2012 04:37 PM
This is info for Mike....I was using mainly the 24-105 lens...tried fine spot focus, regular spot focus and center group focus...
all in one shot mode. Most distances are about 8-12 feet and lens maybe zoom between 24-40mm.
12-02-2012 11:29 AM
04-30-2013 09:31 PM
I have that issue with the 600 ex rt i rented. slight lag from the auto focus lock to the shutter release. but i havent had major issues with af while using a custom bracket. sometimes the flash and the camera arent aligned properly with eachother so i slightly shift the camera to align it with the af beam. i really wish canon would update their oc3 cord with a built in af beam like the nikons do. nikons imo have always outperformed canon in lowlight.
