02-22-2016 03:10 PM
Is it possible to create still images from movies made on a 1200D, please?
I am looking to overcome, when taking photos of wild birds, the problem with the loud noise made by the shutter/flapping mirror which tends to cause many birds to fly away! I thought I could try to produce images from movies which don't involve any camera noise.
02-22-2016 04:20 PM
Save your money, and invest in a top quality super telephoto lens. The further you are away from your subjects, the less you will intrude upon your subjects.
02-22-2016 03:45 PM
@Peter54x wrote:Is it possible to create still images from movies made on a 1200D, please?
Yes, however, it is easier to do it in post., after you have download the movie file to a computer.
You should be aware of a couple of things, though. The video resolution does not compare to the resolution of still photos. Second, at some point you will have to make the shutter noise, to start the video, and you will make the noise again when you stop the video, closing the shutter. Furthermore, you will not be able to keep the shutter open indefinitely because the image sensor will begin to build up heat.
How far away are the birds from you, and what focal length lens are you using?
02-22-2016 04:13 PM
Thank you very much for that speedy and helpul advice. I note that my movies of birds must not be too long in order to avoid creating additional problems. I bought this camera only last Thursday - it's my first DSLR - and I haven't used it outside yet so I cannot answer your focal length question.
The other problem I want to avoid is taking images of birds from a "hide" with the birds being about ten yards away and then seeing the bird(s) fly away when I take my shots and at the same time get annoyed looks from other photographers!
I will proceed with your suggestion of extracting images from movies loaded onto my computer and will give that a try now using the software that came with the camera. Many thanks, again!
02-22-2016 04:20 PM
02-22-2016 05:18 PM
That is very fair comment but the kingfisher I saw last year in a wood near me tends to rest, when it comes close, on a branch very near to the hide. What I will do, though, is try to get good photos of it and other birds when they are much further away. Thanks again.
