Vivitar lens compatibility with EOS Rebel T7
Cyfox
Heyo
I have a cannon rebel t-7 camera and I just got given a vivitar 28-85mm f3.3-f4.5 macro lens and I was wondering if there was an adapter I could buy so I can use it
thank you
3 REPLIES 3
zakslm
Mentor
Mentor
Cyfox,
If you could be more specific as to the which lens mount the Vivitar is fitted with that would be helpful.
If it has an Canon EF compatible lens mount it should fit without an adapter.  A Canon EF lens mount looks like this or may be black plastic like the 18-55 kit lens that may have come with your T7 instead of stainless steel but the gold contacts will be there:
If it isn't a Canon EF lens mount but some other type, then it probably isn't worth the trouble and expense of tracking down an adapter.  My recollection (from my Canon FD days) was that some of the Vivitar Series 1 lenses were good performers, but the lenses that were not Series 1 lenses were just OK.  In any case, it probably won't autofocus on your camera even with an adapter if it doesn't have a Canon EF lens mount.
I have a T7 as well and a benefit to owning a T7 (or similar body) is that any Canon EF and EF-S mount lens ever made will probably work on the camera.  If you're looking lenses, there are a lot of EF and EF-S lenses (Canon brand and other brands) that are available used and refurbished at very attractive prices from reputable sellers like the Canon Refurbished store, KEH.com, Bhphotovideo.com, Adorama.com, MPB.com, usedphotopro.com and elsewhere.
Good luck!
LZ
normadel
The Vivitar you have is a manual-focus film camera lens.
Do you know what lens mount the Vivitar has? Is it even a Canon-mount lens?
If it's a Canon FD-mount, there are adapters to mate it with your T7, but the user experience will be less-than satisfactory.
1.No automation at all with focusing or exposure. Manual settings only.
2. The adapters that provide for infinity focus have low-quality optical elements in them.
Your best bet is to give away the Vivitar to someone who has Canon manual-focus film cameras.
ebiggs1
I don't know of any Vivitar lens that will fit or work on your Rebel without some sort of adapter. But further the lens isn't likely worth the effort or money involved to get it to "work" if it doesn't mount as is.
Re-read the previous post above.
EOS 1DX and many lenses.
