01-22-2024
12:22 AM
09:47 AM
I am wanting to buy the Sigma 150-600mm C for my Cannon Rebel T7 and was wondering if it is compatible. If it is are all the features available and what adapter do I have to buy if any.
Thanks!
01-22-2024 12:58 AM - edited 01-22-2024 01:00 AM
Hi and welcome to the forum:
The Sigma 150-600c is a third party lens that is made for different camera brands, so if you want to get one you need to make sure you get one with a Canon EF mount. With that, you can definitely fit that lens on your T7 without a further adapter.
Because of the crop sensor nature of your camera, while the focal range of the lens is indicated at 150-600, its actual field of coverage will be equivalent to a 240-960mm lens, so brilliant for long shots but you lose some wide angle capability.
I just actually sold my own copy after years of faithful service and it's an excellent performer. There are quite a few images posted in our gallery pages here, to show you its performance on both APS-C crop bodies (like your Rebel) and full-frame bodies.
Search - Canon Community
01-22-2024 01:58 AM
Thanks so much this clears up everything I needed to know! I shoot aviation and nature photography and I think this would be a nice upgrade thanks for the help!
01-22-2024 02:06 AM
You're most welcome. I hope it works well for you!
01-22-2024 08:14 AM
Late to the party but I have that lens. It is a good lens and no adapter needed for the T7. As noted, make sure you get the one for the Canon EF mount.
01-22-2024 08:42 AM
As previously noted, the lens is available in a variety of lens mounts. So, you must make sure to purchase one for teh Canon EF mount.
This lens is significatnly larger and heavier than standard kit lenses. I advise you to always support the weight of the lens with your hands. NEVER allow the lens to hang from the camera mount without supporting its’ weight.
It is okay for the camera to not be supported while attached to the lens. In fact, this is the normal way in which the lens would mount on a tripod with a camera attached to it.
I own one of these lenses. While it can be handheld, I find that my arms can quickly grow weary. I use a tripod or a monopod with the lens, especially for long shooting sessions such as an air show. I mostly use a monopod, though. A monopod is far easier to setup when you are on the move.
01-24-2024 10:37 AM
Great lens, you'll love it.
Two photographic opportunities that will be made more difficult to impossible with a monopod and much more with a tripod is an Air Show or birds in flight.
A back/shoulder strap like Black Rapid can take the weight off your arms when you are not shooting. Gives them a little rest however I shoot the Sport version of the big Siggy and I don't have any issues using it hand held.
01-24-2024 10:49 AM
BTW, while on this subject if you have not already purchased the Sigma take a look at the Tamron SP 150-600mm f/5-6.3 Di VC USD G2 for Canon EF. It is a better lens. I had the wonderful opportunity to use one last weekend. I already knew it was a better lens but man that is an understatement is is a far better lens.
My buddy also had the Tamron SP 24-70mm f/2.8 Di VC USD G2 Lens for Canon EF. It is fantastic and gets in the realm of unbelievable IQ for a zoom. I was thoroughly impressed with both.
07-02-2024 11:59 AM
I have an Canon EOS Rebel T6 is it the same I do aviation photography and I want to upgrade to the Sigma 150-600mm but I don't know if it is compatible can you help?
07-02-2024 01:43 PM - edited 07-02-2024 01:45 PM
To clarify. ANY DSLR including any Rebel will work with the Sigma 150-600, as long as it has the EF mount.
So go for it!
