05-07-2021 05:39 PM
R5 is at firmware 1.3.1, AF operation is "SERVO AF". Lens is at firmware 1.1.0, set to AF, full AF range and stabilizer on.
When I half-press the sutter, the autofocus enganges, but the focus ring does not have an effect (as I expect it should for FTM). The focus ring also does not work after releasing the shutter button - but when I turn off AF on the lens, the AF rings works.
05-07-2021 06:22 PM
To answer my own question:
The 1.3.1 firmware release notes state:
4. Adds [Electronic full-time MF] to the AF tab of the menu. When a lens is attached, manual focus adjustment is always possible with both One-shot AF and Servo AF.
With [Electronic full-time MF] set to ON, the focus ring works as expected in th One-shot AF and Servo AF modes
Phew - glad the lens is not broken 😜
05-07-2021 06:22 PM
