12-27-2013 03:54 PM - edited 12-27-2013 06:28 PM
I have a new 24-70mm f2.8 and want something to compliment it for the longer distances. I'm thinking something between 250-400 would be good but not sure which one(s) are 'better'. This would mostly be used for indoor/stage shooting with some outdoor of kids plays, concerts or playing etc. maybe something in the 55-300 range?
I also have a new 70D (just took it out of the box) ;). So also looking for a recommendation on a USM to use with it for video - something mid range that would be good for most situations.
All input welcome!
12-27-2013 06:24 PM - edited 12-27-2013 06:29 PM
Should have mentioned that i have a Sigma 70-300mm f4-5.6 - i like the range but do not find it very sharp thus looking for something else ...
Wondering what folks recommend?
And also what the preference is betweeen the 70-200 f/4L vs the 70-300 f/4-5.6L??? I believe they are close in price.... is one sharper than the other? Are any of the other brands worth looking at in this range?
Oh and i had said "USM" but meant "STM" for video on the 70D - the super quiet ones good for video...
12-27-2013 06:37 PM
If you're thinking high quality zoom both the 70-200 L's and 70-300 L IS are worthy contenders. I haven't used the 70-300 but have read a lot of very good reviews praising it's AF speed & image quality. The one weak spot may be that it's not fast enough for some indoor stuff.
12-27-2013 06:41 PM - edited 12-27-2013 06:52 PM
Thanks for quick reply! Really appreciate it!
Will have the check the price locally for them and the weight - that is really my only concern - i can't lug around heavy lenses ;( wish i could but my neck and back won't allow it ;(
The faster the better 😉 and also why i'm open to other brands - to hopefully lower the cost.... can't afford another expensive one after the 24-70 f/2.8L !! 😉
12-27-2013 07:06 PM
What about the Canon EF-S 55-250mm f/4-5.6 IS STM lens? Doesn't get me to 300 but a lot cheaper! From what i read it is pretty sharp?? obviously not as nice as an L 😉
12-27-2013 07:29 PM
Can't comment on it from use but I've read both good & bad. From what I've read the only other serious contender may be the Tamron 70-300 VC.
12-27-2013 07:36 PM
I will warn you that there is a learning curve to shooting longer lenses, so as you pass 200 mm things need to be done more carefully re shutter speeds & keeping things steady, and with you using a crop body it's even more important to develop good technique.
12-28-2013 11:18 AM
Oh, BTW, that same lens is available in a crop sensor "DC" version as the 50-150mm f2.8 EX DC OS HSM.
But since you indicated you wanted a little more reach, 300mm, the 70-200mm version will yield an equivalent 320mm on your camera.
12-28-2013 06:59 PM
12-28-2013 07:29 PM
"... pics are not sharp and not sure why ..."
You are talking the Canon 24-70mm f2.8 II L? This lens is scary sharp!
