12-29-2013 12:56 PM - edited 12-29-2013 01:20 PM
I have a 24-70mm f/2.8L lens and am finding that it is not as sharp as i'd expect. I'm sure it's me and not the lens so hoping someone can help me understand what i'm doing or not doing correctly.
I'm attaching a picture as an example...hand held...here are the settings:
EF24-70mm f/2.8L II USM
59.0mm
1/640 sec; f/2.8; ISO 400
Shutter priority; Spot metering
shot with 70D
when you zoom into the tree it is cleary not in focus/sharp ;(
I've tried at differen shutter speeds but still having the same issue... going to try different apertures next...
01-03-2014 01:28 PM
Just checked - it will 😉
01-03-2014 05:37 PM
In Sigma the DC designation means APS-C and DG means FF.
01-01-2014 09:47 AM
Maria, that particular lens (which I have owned and used for years) is simply NOT sharp when used wide open at f/2.8 but improves when the aperture is stopped down to at least f/4. It becomes quite sharp at f/5.6 - f/8. I avoid using mine wide open. Normally this is not a problem as most of my shooting required apertures between f/5.6 and f/11.
01-01-2014 11:24 AM
"... is simply NOT sharp when used wide open at f/2.8 ..."
WOW, I can't believe you or anyone said that!
As a common fact no lens is a sharp wide open as it is stopped down several stops but this lens is outstandingly sharp.
The only complaint I could possibly give it is, wide open at very close distances but who shoots one that way anyways?
This lens is as good as it gets. There simply is no better lens (in a 24-70mm f2.8) even with Brand N.
IMHO, of course, ... as aways.
01-01-2014 01:16 PM
I guess the next thing you'll try to convince me of is that your version 1 of the 70-200 is sharp wide open and is as sharp as the version 2.
For the record, most lenses only need to be stopped down 1 or 2 f-stops to get to the sweet spot, not several.
Also, for you to say there is no better 24-70/2.8 class lens out there than the Canon version 1 is simply wrong. You should check your facts before making such a claim.
Have a nice day. I'm done with this conversation.
01-01-2014 01:30 PM
"I'm done with this conversation."
GOOD!
01-01-2014 09:49 AM
P.S. I use the lens on 2 bodies..... a 1D Mark IV and a 5D Mark III. Results are the same with both bodies.
01-01-2014 11:28 AM
I had this same problem with my EOS 60D. soft focus. I had to finally send it in to canon to be tweaked and fixed, after trying EVERY other thing and asking every single person who would giveme an answer. Sometimes after time and use cams just need to be adjusted
01-09-2014 09:16 PM
01-11-2014 08:02 PM
