Please Help - why are pics not in focus and sharp?
Maria
Enthusiast
I have a 24-70mm f/2.8L lens and am finding that it is not as sharp as i'd expect.  I'm sure it's me and not the lens so hoping someone can help me understand what i'm doing or not doing correctly.
I'm attaching a picture as an example...hand held...here are the settings:
EF24-70mm f/2.8L II USM
59.0mm
1/640 sec;   f/2.8;   ISO 400
Shutter priority;   Spot metering
shot with 70D
when you zoom into the tree it is cleary not in focus/sharp ;(
I've tried at differen shutter speeds but still having the same issue... going to try different apertures next...
____________________
Body: Canon 6D, Canon T1i, Canon Elan II,
Glass: Canon 24-70mm f/2.8L II USM, Canon 70-200 f/4 IS II, Canon 16-35 f/4, Canon 100 f/2.8 macro.
Flash: Canon Speedlite 430ex ii
52 REPLIES 52
On the close up pics, the 70D shot is not in focus. It may or may not need microfocus adjusting. There are lots of resources online as to various methods for doing that.
It's nice that Canon brought that feature back into the XXD line with the 70D.
Good luck.
http://trulandphoto.zenfolio.com/
http://trulandphoto.blogspot.com/
TCampbell
Hi Maria,
Whenever the focus performance of a lens is in question, you NEED to use a focus target to test the lens rather than using a real photo. There are just too many things that can go wrong with a real photo.
For example, you've used an f/2.8 f-stop... at a 10' focusing distance, the depth of field for that focal ratio is less than 1'. It would be very easy for focus to end up on the wrong object and throw the focus.
By using a focus test chart and putting the camera on a tripod, picking the middle focus point, centering that on the mid-point of the test charter, and repeatedly taking shots (I de-focus the lens after each shot to force it to re-focus and half the time I run the focus out to max distance and half the time I run the focus in to the min distance... and keep track. Sometimes a lens can have a problem focusin in one direction... but not in the other (or the margin of error will be different depending on the direction it had to turn focus.)
You can buy a commercially made test chart... but you can also download and print out your own. Just make sure you follow the directions carefully. Here's a pretty good chart you can freely download: http://regex.info/blog/photo-tech/focus-chart
Most lenses tend to provide their sharpest performance stopped down a few stops (not wide open). Typically somewhere between f/5.6 and f/8 will yeild the best performance but it varies by lens.
It is entirely possible that you have a bad copy OR that there's an issue between the focus calibration of that lens with your specific camera (in other words, a different copy of the same lens might perform differently.)
I believe the 70D also supposts auto-focus micro adjustments -- but before plunging into that, you'll want to be sure there really is an issue.
Tim Campbell
5D III, 5D IV, 60Da
yes it does have micro adjustments 😉 but need to be sure of what the issue is before doing anything...
i read that test info - not sure i completely understand but will try tomorrow in good natural light...
my fear is that there is a problem with the lens - i purchased it in late September - so no way i can return or exchange now ;( with the T1i i could see that it was a little off but assumed it was me and the need for me to learn more vs the lens... but now with the 70d it is very obvious that it is way off ;(
i'm starting to feel very sick at the thought that it is the lens... if it is i think it has a 1 yr warranty so hoping that means i can have it looked at???
Does the 70d have any focus problems with other lenses? I guess it would be too much to hope for to see if someone has accidentally thumbed a bad AFMA value into your camera, and the lens is fine?
Or perhaps a modest AFMA will set things to rights?
Good luck. Keep everyone posted on your checks.
Scott
Maria the picture of the label is unacceptable for a 24-70mm f2.8 L lens. Smiley Sad
But cameras and lenses only do what you tell them to.
It is imperative that neither moved during exposure. That makes the tree useless for now.
Also the DOF at f2.8 is very thin.
It is imperative to find out which of the three variables, the lens, the body or you are at fault. Until you know which, you, and/or us are blowing in the wind.
Don't go messing with any controls or adjustments on the camera. Plus make absolutely sure the camera is set to factory defaults.
Do you haveor can you go back to the store and try another lens on this body?
Do you own a tripod?
EOS 1DX and many lenses.
@Maria wrote:
I'm using the center AF.... i tend to use it 90% of the time... the text pic i just posted looks better but still thought it should be better than it is.... i found this: Jeffrey’s Autofocus Test Chart (http://regex.info/blog/photo-tech/focus-chart) so going to try it next - but not sure i fully understand what to do...
You'll download and print the chart on your printer.  You'll place the chart so that it's leaning away from the camera at approximately a 45 degree angle (it doesn't need to be perfect... just make sure it's leaning back on a slope).
You'll put your camera on a tripod so that that there's no way it can move after focusing.
You'll select the center focus point on the camera and frame up the shot so that the center point on the camera is pointed to the middle of the focus chart ... it is crticially important that you make sure the center AF point is exactly on the bold spot in the middle of his chart and not off to a side or above or below.  The center has extra strong contrast to make it easier to find.
Now you can focus the camera and take a shot.
After you've taken the shot... inspect it.
If the lens is "front focusing" (true focus distance is actually closer then your intended focus distance) then you'll notice the text toward the bottom of the chart will appear to be focused better.  If the lens is "back focusing" then the top of the chart will have better focus.  If the lens and camera are performing correctly... then the middle of the chart (the point you actually used to focus) will have the best focus.  This is why the chart needs to lean back on an angle... so that part of the chart is closer and part of the chart is farther away.
If the lens is consistently off in the same direction, you can apply a focus adjustment for that lens in your camera.  If it's randomly off then the lens will need service (and it's even better if you send in BOTH the lens AND the camera so that Canon can calibrate the lens specifically for YOUR camera.)
Tim Campbell
5D III, 5D IV, 60Da
I'm going to try the test to see what happens. Depending on what I find I'm going to take the lens to the place I purchased it (Henry's) and see if they will do anything. Going to print it now...
 i printed out that chart and took some shoots .... part i'm not clear on is how far away from the camera is chart supposed to be?
edited: just re-read the instructions - it says 10 feet! 😉 will try again....
Harv
Maria, that particular lens (which I have owned and used for years) is simply NOT sharp when used wide open at f/2.8 but improves when the aperture is stopped down to at least f/4.  It becomes quite sharp at f/5.6 - f/8.  I avoid using mine wide open.  Normally this is not a problem as most of my shooting required apertures between f/5.6 and f/11.
Harv
P.S.  I use the lens on 2 bodies..... a 1D Mark IV and a 5D Mark III.  Results are the same with both bodies.
