09-25-2018 11:19 PM
I just ordered my first prime lens from B&H. The Canon EF-S (I know, I know) 24mm f/2.8 STM.
I did this for a couple of reasons. First, was the fact that I've been getting a little more into street photography, and while I had been using my 18-55mm kit lens, I was finding it bulky at not so well suited for my needs. The 24mm prime, with an effective focal length of 38mm, would be ideal for me. I prefer it over a 50mm for street work. And I can use it in the field, in deserts and so forth. Then there was the cost of the lens itself. At $129 brand new, it seemed quite inexpensive. No, it is not for a mirrorless rig, but it didn't cost $2000 either. So until such time as I make the inevitable move into mirrorless, I think I got a good deal on a lens that I will be using plenty. Have any of you used the 24? What are your thoughts?
09-27-2018 07:47 AM
09-27-2018 08:28 AM
Not exactly, You use a depth of field calculator, find the dof limits for a particluar f number and set the focus for a point about 1/3 past the fist one.
http://www.bobatkins.com/photography/technical/doftable.html
09-28-2018 09:29 AM - edited 09-28-2018 09:30 AM
Thanks guys, I've been reading up on using hyperfocal distance and have downloaded a calculator to my phone. Seems like a simple enough concept, if I can accuarately judge the distance LOL. I'll try it out this weekend.
09-28-2018 02:40 PM
That is one of the reasons that distance scales have survived.
09-28-2018 03:14 PM
@kvbarkley wrote:That is one of the reasons that distance scales have survived.
Exactly. Finding the hyperfocal distance focusing point is easier with a distance scale.
09-28-2018 03:18 PM
@kvbarkley wrote:Not exactly, You use a depth of field calculator, find the dof limits for a particluar f number and set the focus for a point about 1/3 past the fist one.
Not exactly is what I said. But, it does work out to be nearly the same spot as infinity focus.
https://www.dofmaster.com/doftable.html.
I browse that table every so often when I want to choose lenses to carry, and aperture settings to use.
