05-31-2017 07:23 AM
What is a afordable and good lens for plane spotting photography?
06-02-2017 09:39 AM
Not necessarily a great choice & I'm a fan of superzooms. It may not be able to AF fast enough. I'd check the reviews before buying.
06-02-2017 10:47 AM
" I'd check the reviews before buying."
I agree. That is probably a lens you want to cross off your list.
06-02-2017 10:57 AM
I believe he is talking about the new 70-300 II, which by most accounts, is a good lens.
06-02-2017 11:02 AM
It would not have to be much better to be better! Still not impressed!
06-05-2017 02:35 AM
Well I meant I was getting a 75-300 lens is it good?
06-05-2017 08:40 AM
There are several versions of 70-300 or 75-300 mm lenses. Some are very basic with less than ideal AF or IQ. The more you spend the better the lens will be feature & quality wise. One thing I can recommend you look for while researching them is a lens with Image Stabilization which can be used when panning. (IS when panning can be very important with the lower shutter speeds used to produce prop blur.)
