11-07-2024 04:05 PM
I'm using a Canon EOS R7. Looking for a good lens to cover indoor basketball. I sit just under and to the side of the basket. Looking to spend no more than $600. Any ideas / advice?
C2C
11-08-2024 08:42 AM
I'm sure others would agree, you will be very pleased with your decision. The R6 Mk II is a great start to the hobby.
R5 Mk II ~ R6 Mk III ~ R7
Lenses: RF Trinity and others
Personal Gallery
11-07-2024 04:11 PM
What lens do you have?
Do you have the RF to EF adapter?
11-07-2024 04:14 PM
The RF 100-400 is $650, which would be the best bet for your budget.
11-07-2024 04:17 PM
Thx for the feedback - very much appreciated. I'm about to buy the R7 with the adaptor. If I use that Rf 100-400 will my pix be better than what my t8i has been producing? I'm worried that I wont be able to shoot lower than F/5.6.
11-07-2024 04:49 PM - edited 11-07-2024 04:51 PM
That's the challenge you have, at your budget you are not going to pick up a fast lens. I have the RF100-400mm and its a nice lens, fast focus, sharp and light weight.
I normally use a 2.8 for indoor sports, some say f4 is fine. You will have to bump up your ISO which will result in more noise. Do you have software that can assist with noise reduction?
Personal Gallery
11-07-2024 05:20 PM
Really appreciate the feedback/mentorship. I’m certainly new to all this.
Use Adobe LR for processing.
do you think the 100-400mm will be OK in the gym or under the lights in a football stadium?
ready to buy the R7 - just hesitant because of noise.
11-07-2024 06:03 PM - edited 11-07-2024 06:04 PM
C2C,
Lightroom does have a decent denoise tool so that will help you depending on the path you take when purchasing equipment.
I think the RF100-400mm is going to struggle in low light, and the R7 also has some challenges with noise. It sounds like you have a budget that you are attempting to maintain which is a good practice. Hopefully kvbarkley and others will jump in with their thoughts.
Personally I do not use my 100-400mm in low light, it struggles resulting in high ISO and quite a bit of noise.
It's a tough decision, budget over what equipment to purchase. I use my 100-400mm all the time but with no disrespected intended towards kvbarkley recommendation I am not sure this would work for low light sports that will require higher shutter speeds.
Also, if you are in the US try to look at the Canon USA site. The refurbished section has a lot to offer. I have made several purchases from there, the products are like new and the prices are reduced. There is an R6 Mk II that would be a good by @ $1760 if you can swing it.
Personal Gallery
11-07-2024 07:24 PM
Thx for this - again, very much appreciated.
I'm trying to remain south of $2K. Would be great to grab a R6 MKII. With an adaptor I assume I could use my EF 70-250.
11-07-2024 07:46 PM
I started this post about 3 hrs ago... got called away. Late to the game, but see you got some good responses.
I think that your current budget , camera and potential lens choice might impede or keep you from achieving your goal of indoor sports photography. In order to capture motion, you will likely need to use a fast shutter speed. The RF 100-400 has a variable aperture. F5.6-8. I think it's highly probable that you will experience challenges capturing photos indoor using a shutter speed that is fast enough to freeze motion with the minimum aperture this lens is capable of. The R7 is not known for exceptional low light performance. High school gymnasiums may not be well lit.
So as you can see we are of similar belief regarding this camera / lens combination for indoor sports.
Sorry I was late to post. 🙂
11-07-2024 07:59 PM
What do you think of the R6 Mark II? That would be better, correct?
