Lens filter for EF 50mm 1:1.4 lens?
AlyssaHuberFilm
Every time I shoot (video mode) with a 58mm lens filter of any type on my EF 50mm 1:1.4 lens, there is a noticable reflection in view. But I can't shoot without a filter (I always use polarized) because I can't get them to look that good in an editing program. My whites are too bright in outdoor shooting, and the only way I can see the sky is if I make the rest of the scene too dark. A polarizing filter seems to be the only thing that fixes that.
Are there any other filters or accessories I can use instead of the 58mm filters? I know it'd look better if the filter was closer to the lens since the lens is sort of concave... would smaller filters fit?
Or better yet, is there a way to balance my lighting & color in outdoor settings that doesn't require a filter?
I've already tried changing the ISO, exposure, etc. and the white balance. Still no luck.
(My camera is a Canon EOS Rebel T2i with an EF 50mm 1:1.4 lens, shooting in video mode.)
10 REPLIES 10
A lens hood is still highly recommended. My preference is for a collapsible hood that I leave on full time.
If you were getting reflections on the glass filter, then the sun is hitting the front of the lens. Try this, take a shot normally, in the bright sun. Then hold a piece of regular, kraft (brown) cardboard over top of the end of the lens to shade it. Check the quality of the two shots. If there is any washed out areas or reflections in the first shot then get that lens hood.
If they are both washed out, bluish tint, way over contrasted, or whatever, check your WB (white balance). Put it on auto. That satisfies 99% of people. To be more exact before each shot, you could manually set it each time to the ambient environment. I leave mine on auto as I don't want to have to take several minutes setting up a shot.
If your shots still seem over or under exposed, and often a second opinion helps on subjective observations, then adjust your exposure. Try it in half step increments with a variety of shots for each step until you are happy. Remember that there is your eye, the computer's monitor, the ambient light, and the viewer's subjective interpretation. They can all help influence what is or isn't a decent exposure. And, while photographers like to be perfect and create perfect shots, viewers are much more lenient in their judgement.
