10-09-2021 12:13 AM
While recently attempting some panoramic photography, I was using f-numbers of f/11 to f/16 to increase the DOF. Later I wondered whether light diffraction was spoiling some of the image quality. My equipment was a 7DII and Canon 16-35 mm IS USM f/4 lens.
Using some basic optics, even with a perfect lens, each point on the object is not focused to a point on the sensor, but to a blurred area roughly 2.44*f*lambda/D, where f is the focal length of the lens, lambda is the light wavelength, and D is the lens's aperture diameter. Since the f-number is defined as f/D, the blur reduces to 2.44*lambda*f-number. My camera's pixel size is 4.1 micrometers. If my math is correct, and assuming an average wavelength of 0.55 micrometers, even at f/4 the blur is 1.4 pixels. At f/16 it is 5.2 pixels.
What I don't know is how much this matters to image quality. In the future I plan to examine my photos closely to see whether the theoretical blurring vs f-number actually matters. Has anyone looked into this? I would appreciate some experienced feedback!
Many thanks,
Ed
(Trying to watch Giants vs Dodgers while writing!)
10-12-2021 02:08 PM
@ebiggs1 wrote:Ed,
This is not correct.
"the diffraction blurring does not depend on the lens focal length, but only on the f-number."
Diffraction is worse with WA and UWA lenses because of the short FL. Why? Because the hole in the diaphram is smaller at any given f-stop compared to the same f-stop in a normal or tele typle lens. In a WA/UAW the light path is bent at a greater angle.
__________________________________________________________________
EB,
After your interesting comments, I looked into this topic some more. My conclusion about the importance of light diffraction in lenses was based on thinking about a singlet lens with an aperture right next to it. Of course, modern lenses are complicated affairs and designed my specialized optics engineers. Nevertheless, my conclusion still holds, namely, that the diffraction blurring on the camera sensor is proportional to:
2.44 * lambda * f-number
The entrance pupil diameter, which makes up part of the f-number, is defined as the image of the len's aperture stop as seen from the object (front) side of the lens. The link below corroborates the conclusion above. (Since I haven't tried to include a link on this site before, if it does not work just go to Wikipedia and search "Diffraction-limited System".
https://en.wikipedia.org/wiki/Diffraction-limited_system
For me, it is always helpful to be able to understand things in the simplest, most reduced way, and this is an example. It makes learning easier.
Respectively,
Ed
10-12-2021 05:08 PM
Ed,
I have no idea about math so that stuff is wasted on me. I only know from experience. WA and UWA suffer more diffraction from a given f-stop than teles do.
So I must repeat..........
Sometimes stuff is made a lot more difficult by reading too much. Sometimes it is the simple explanation.
10-12-2021 06:07 PM
Diffraction blur depends upon F number and the size of pixels on the sensor. It does not depend upon focal length or physical aperture diameter except that F number is calculated from both focal length and aperture diameter. For the same lens, a different sensor will have a different diffraction blur. There might be sources of blur other than diffraction blur, for example depth of field or motion. The combination of focal length and F number will change depth of field blur.
There is a simplified explanation with diagrams illustrating the math and example calulators at https://www.cambridgeincolour.com/tutorials/diffraction-photography.htm
When using a Richardson/Lucy deconvolution to remove diffraction blur, the radius must be chosen based upon the F number and the spacing of pixels on the sensor.
10-12-2021 07:04 PM
Agreed, johnrmoyer.
10-13-2021 09:39 AM
"Diffraction blur depends upon F number and the size of pixels on the sensor."
I already stated that.
" t does not depend upon focal length or physical aperture diameter except that F number is calculated from both focal length and aperture diameter."
Yes it does. Why? Because the light rays are bent more in a WA/UWA than it is in a tele lens. As FL increase the diameter of the aperture is also increase. This bends the light less. This is simple to understand if you don't understand or reject it I have done all I can.
