08-08-2016 07:55 PM
Hello,
I own a canon T6i and i've been using it with an EFS 18-55 with no trouble at all.
Recently I bought a 50mm EF lens f/1.8 STM. And I don't seem able to use it. I connect both red dots, the lens never clicks with the camera and then I can't focus the lens at all.
What am I doing wrong?
08-08-2016 07:57 PM
Are you turning the lens until it locks into place? It should lock afer about a quarter turn, just like your 18-55mm lens.
08-08-2016 08:10 PM
First of all, thanks in advance for your help.
Ok, so it should click as I imagined.
My problem seems to be that i can't manage it to lock into place. I do turn the lens
I tried tightening it a lot but I'm also afraid I might break something.
Its really easy with the EFS,
so maybe the lens came broken?
08-08-2016 08:25 PM
It is possible there could be something amiss with the mount. One can never rule that out, however unlikely it might seem. If you purchased it locally from a brick and mortar store [instead of online] try taking it back, and let them take a look at it.
Maybe you need an exchange. It shouldn't be all that difficult to attach and detach.
08-09-2016 12:56 AM - edited 08-09-2016 12:56 AM
Are you matching the red mark on the EF lens with the red mark on the lens mount? My EF lenses work fine - including the 50.
08-09-2016 07:38 AM
And remember the camera has two dots; one red and one white, for EF and EF-s lenses, respectively.
You had previously always been attaching your EF-s lenses to match up WHITE dots on camera and lens.
The EF lenses match RED dots, not using the white one on the lens.
08-09-2016 07:41 AM
And it may not give a loud click. The important question is whether it is locking in and not turning back out unless you press the lens release button.
