12-06-2019
03:21 PM
09:39 AM
I am using a Canon EOS Rebel SL2 with a Canon EF-S18-135mm f3.5-5.6 IS STM lens. Is there an easy way to set the focus on infinity when I'm using MF mode on the lens? I just want to set it and forget it.
10-11-2024 01:58 PM
Well, 5 years in camera business is not that long. I had this question for a while (and still hope there is a better solution) and found this post but not a solution to the problem. So hoping that people with RF lenses (6 years old) can find it useful. If you knew the solution before somebody passed away - why did not you answer?
10-12-2024 09:36 AM
I did and it was the "accepted solution".
