EF-S 10-22mm vs 15-85mm
calilove27
I've received some great answers and advice on here, so I'm back for more (:
So again, I just bought a Rebel T3i with the 18-55mm lens kit. I've recently asked for some lens suggestions regarding that majority of the time I take landscape photos, but I still take photos such as sports, portraits, and cityscapes. In addition to that, I'll be taking a trip to Las Vegas and Los Angeles this summer, so one of my focuses while I'm there is taking night photos of the city lights. I have no knowledge about taking night photos, but I'll be doing some research and I'll try to learn everything as quickly and effectively.
With that being said, quite a few people on here recommended that I get the EF-S 10-22mm lens. Others also recommended the EF-S 15-85mm. I've researched both lens and they both seem great for the type of photos I take and I would love to purchase both, but I'm somewhat on a budget.
What I'm thinking is should I just keep the 18-55mm kit lens and add the 10-22mm lens, or switch it around and get the 15-85mm in addition to the 18-55? or the third option and sell the 18-55mm kit lens and buy the 15-85mm?
amfoto1
I don't like the 10-22mm and 15-85mm combination.... With only a couple lenses in your kit, that's too much overlap. If it were me, here's what I'd do....
1. Get the 10-22mm USM ($650 new, $500 or less used... plus lens hood $32 OEM, $20 3rd party... Total $520 to $680.)
2. Sell the 18-55mm (you probably won't get very much money for it, likely less than $100, depending upon version. The IS is newere & better than the non-IS version. The STM & IS version is newer & better than the IS version).
3. Buy a used EF 28-135mm IS USM. There have been so many of these sold in kit that they're pretty easy to find lightly used for around $200 to $250 US. This really isn't a kit lens, but an older design that still  works quite well. It rivals the far more expensive 24-105L ($1150 new, $700+ used) for image quality and performance, just isn't as well built or sealed. I have two of these lenses... one cost me under $200 with OEM lens hood. The other cost me $250 with OEM hood and a high quality, 72mm filter (about $75 worth).
I'm pretty confident you could do all the above for well under $1000 and have a pretty versatile 2-lens kit. I figure between $720 and $930, depending upon how you buy and the deals you find. If you sell your 18-55mm kit lens for a few $, that would reduce your total cost a bit. As I recall from your earlier posts you had a budget of around $1000 total.
If you also want a "portrait/low light" lens, add an EF 50/1.8 II for around  $125. Or even better, get an EF 50/1.4 USM, which sells for about $340 new (on sale now at B&H Photo), $300 or less used. Add another $15 to $26 for the ES-71 II lens hood, if it's not included. (Note: WIth this lens you must get and use the lens hood. When shooting it protects the front barrel from bumps. When stored in the reverse position, the hood covers and protects the focus ring. This lens is known to have a fragile focus mechanism, but seems to do just fine if it's given these reasonable and normal protections. It's also recommended not to do a lot of manual focus overriding of AF with this lens. My copy of the lens is 10+ years old and still going strong.)
The 50/1.8 II is a good entry level lens. It's capable of quite nice images and is a useful introduction to using a large aperture prime lens. But it is very lightly built and plasticky, and it's auto focus is slow, noisy and somewhat inconsistent. The 50/1.4 has incrementally better image quality, the differences are subtle, but it has less flare, better contrast, better color saturation, nicer background blur. Probably more importantly, it's AF is much better even though it's an old design and a hybrid form of USM.
The zoom lens combo above would give you pretty thorough coverage from 10mm to 135mm, which is actually more than most film photographers ever enjoyed with their SLRs back in the good old days. Many of them got a 50mm lens with their camera, added a 28mm wide angle and a 70-210mm tele zoom. That was a very common kit. On your T3i, 10mm to 135mm is equivalent to 16mm to 216mm on film/full frame.
Now, I don't mind carrying a camera bag with a few lenses.I do all the time. However, traveling you might prefer to only carry a single lens, for convenience and simplicity. The EF-S 15-85mm USM IS would be a very nice choice for that. It has excellent image quality and very good all around performance. It's a $700 lens new, or about $550 used. The EW-78E lens hood for it sells for another $15 to $30.
While the 15-85mm is a very nice lens, quite wide at the one end and covering ideal portrait short telephoto focal lengths at the other end of the zoom... There's a big difference between 10mm and 15mm wide. And 85mm is not typically going to be long enough for sports. (135mm is better, but really isn't long enough either, so either way you should start saving up for a longer lens.)
If you are in the US, I'd suggest looking at the larger online retailers (Amazon, B&H Photo, Adorama) for new items. For used, those also work, plus there is KEH in Atlanta. Also check out the Canon online store. There are sometimes refurbished lenses there, too. Refurbs and used from these sources usually come with some sort of warranty. Sometimes it's every bit as good as a new item warranty, other times it's a bit less time.
Locally, for used items check on Craigslist... but be very careful. Only meet in a safe place (inside a bank lobby or busy coffee shop), take your camera and test anything to be sure it's working, before handing over any money. There's no warranty buying this way!
A third possibility... if you didn't have a lot of use for it after your trip, you could rent a 10-22mm for those Vegas and LA visits. However, I think you mentioned previously an interest in landscape photography and ongoing cityscape shooting.... both of which suggest to me that you will want to buy that lens rather than rent it.
Hope this helps!
Alan Myers
San Jose, Calif., USA
FLICKR & PRINTROOM
9 REPLIES 9
ebiggs1
There is no doubt the EF15-85mm is a better lens that you kit lens but you certainly don't need both!
If you sell the kit lens you won't get much as there are many on the market.
The EF-S 10-22mm is a more limited specialized lens. So it is going to excel at what it does. But again that is the fantastic thing about a DSLR. You can taylor your equipment to the job.
So best combo from what you stated is EF-S 10-22mm and EF 15-85mm.
I must admit that would not be my first choice but it is what you said.
I would go for the EF 24-105mm f4 L along with the EF-S 10-22mm.
To keep the cost nearly the same you will have to find either a white box 24-105 or get a good used one. There happens to
be a lot of these around, too. Finding one will be easy.
But this combo is going to be way more versatile and will suffice you for a long time.
EOS 1DX and many lenses.
I was looking at the EF 24-105mm f4L as well as the 24-70mm f4L, but knowing that the L lens are more meant for full frame bodies, I kind of backed off from those lens, since I have a cropped-frame body camera.
amfoto1
Hope this helps!
Alan Myers
FLICKR & PRINTROOM
Okay so for now, I am going to buy the 10-22. Right now I'm lookng at a lens kit deal on bestbuy.com for about $660. The package includes "EF-S 10-22mm f/3.5-4.5 USM Ultra Wide Angle Zoom Lens, Zeikos 3-Piece Multi-Coated Glass Filter Kit (77mm UV/FLD/CPL), Precision Design EW-83E Lens Hood for (Canon EF 16-35mm f/2.8L, 17-40mm f/4L, EF-S 10-22mm), CapKeeper 2 and Precision Design 6-Piece Camera & Lens Cleaning Kit"
 does that kit seem good?
And I know you mentioned an lens hood OEM; do you have a link to where I can buy one?
"... do you have a link to where I can buy one?"
Yes, get it here and hood .
Shipping is free. There may not be any sales tax depending on where you live. Plus you get 2% cash reward towards future purchases. Much better deal. Smiley Wink
"And I know you mentioned an lens hood OEM ..."
If you would rather have OEM hood
Thank you 🙂
You are very welcome.
Between me and Alan Myers, you are certain to be successful in your photography future.
I think he is a little younger than me so he has a better feel for all the newer stuff. He certainly can give very detailed advise.
I retired over 10 years ago and shoot mostly for pleasure these days. I sold my darkroom and studio equipment back than as I thought I was through. But I guess it never gets out of your system. I just shoot the jobs I want to now. Much more fun.
All the best cause this is just the beginning, I'm sure.
Or, considerably cheaper used (E+) alternative at Adorama or refurbished at the Canon Online Store.
Hey, I've got some Scottish in me and like to save $100+ when I can!
Used item at Adorama has a 90 day warranty (and I've bought used & refurbs from them in the past... no problem).
Refurb at Canon Store has 1 year warranty.
I also probably wouldn't use the filters included with either of those "bundles". A good quality 77mm filter costs at least $50 to $75 (and my lenses are "filterless" most of the time anyway, by choice). I also don't care for the "cap leash" (my jeans have pockets that serve quite well for lens caps).
Either hood would work.
Alan Myers
FLICKR & PRINTROOM
