EF 70-200 f2.8 II Stops Focusing after a few hours of shooting
kalw63
I bought a used EF 70-200 f2.8 II from KEH a couple of years ago. It was rated as EX (excellent) by KEH. It usually works perfectly for casual shooting or covering short events/sessions, but when I shoot sporting events, it loses the ability to focus after a few hours. I'm shooting outside typically in pretty warm weather (80 degrees F / 26 degrees C), and I'm not sure if that may have something to do with it.
I use a 7D mk II body with the lens, and am shooting roughly 2,000 frames per day; the problem begins after about 1,000 frames. I use back button focus.
Has anyone else ever had this or a similar problem, and if so, how did you solve it?
3 REPLIES 3
Waddizzle
Are you using any custom shooting modes?
Also, a low battery slows frame rates and AF speeds, but not stop working.
ebiggs1
The only thing you can do is reset the camera to default to make sure it isn't a setting. Try it. However, the lens is probably faulty and needs service. KEH doesn't do anything except look at a lens and give it a rating. Oh sure, they may stick it on a camera to make sure it works but that's it.
