06-01-2023 11:43 AM
I’m looking at purchasing the RF 35mm 1.8 as I want another lightweight lens as a walkaround during festivals as such.
I love my 50mm so much, but sometimes I wish I could capture more of the scene and crop as I wish in post. One example is a fairly small stage that even when I’m right at the back on the marquee - I can only just get the whole band in view.
I do have the 24-105 L series but it’s too heavy to have with me all day, I save that for when I really need to zoom in.
Am I right in thinking the 35mm gives me a greater field of view? I was looking at a cheapy EFS 24mm pancake otherwise - which Google tells me crops to 38mm but may have a problem with vignetting.
I tend to photograph people and musicians, indoors and out.
If you were me, would you go for the RF 35 or EFS 24?
Thank you!!
06-01-2023 12:40 PM
I will leave the choice of focal length up to you. You listed a variety of focal lengths.
It is better to use an RF mount lens on an R series body, over using an EF mount lens with the RF-EF mount adapter.
06-01-2023 12:59 PM
Yes, a 35mm lens will give you a wider field-of-view than a 50mm lens (horizontal angles about 54º vs 39º respectively).
The RF-S 24mm lens would have a horizontal angle of around 49º. So you'd be better off with the RF 35mm.
06-01-2023 02:49 PM
If you find the 24-105mm too heavy, then I would recommend the upcoming RF 28mm f/2.8 STM, or a similar wide angle prime for the RF mount.
https://www.usa.canon.com/shop/p/rf28mm-f2-8-stm?color=Black&type=New
06-02-2023 03:06 AM
You're not clear about what camera you're talking about. When you say "Canon R", do you literally mean the Canon EOS R?
On a full-frame camera, like the R, an EF-S lens is a bad idea. It will put the camera into crop mode, which means you will get a narrower field of view -- that EF-S 24mm lens would give you a field of view equivalent to to a 36mm. (It's still a 24mm lens, but the camera is reading a smaller part of the image.)
Worse, you will only be using a percentage of the camera's pixels, so you will be getting much less resolution than you're paying for, like 11.6 megapixels instead of 30.1.
OTOH, if you're looking at APS-C cameras, like the R10, then it doesn't matter.
