EF 16-35 II on R6
enriquehoja
Hi all,
I recently acquired this EF lens, the II version secondhand and have noticed that unlike the RF 15-35 I tried, no focus scale is indicated in the EV or LCD and that with manual focus the ring does not stop at either end (zero or infinity). Are these issues to be expected? Thanks
3 ACCEPTED SOLUTIONS
jaewoosong
Rising Star
Rising Star
I tried my EF 16-35 II on my R5 and verified that it does not show the focus scale.  My 2 other RF lenses do show the scale.
-jaewoo
Rebel XT, 7D, 5Dm3, 5DmIV (current), EOS R, EOS R5 (current), R50V (current)
What your seeing is normal for a USM lens with mechanical AF override. The focus ring will continue turning 360 degrees. Have you ever used an EF Mount USM lens. Almost all of them work this way. Micro Motor USM lenses DO NOT support MF override. Except the EF 50mm F/1.4 USM lens. It has an additional clutch system to allow MF override just like ring type USM lenses have. Some USM lenses use an electronic focus ring like STM lenses. All RF lenses whether STM or USM use an electronic focus ring.
-Demetrius
Current Gear: EOS 5D Mark IV, EF 16-35mm F/2.8L III USM, EF 24-70mm F/2.8L II USM, EF 50 F/1.8 STM, EF 85mm F/1.8 USM, EF 70-200mm F/2.8L IS III USM, 470EX-AI & 600EX II-RT
Retired Gear: EOS 40D & Sigma 17-50mm F/2.8 EX DC OS HSM
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF F/2.8 Holy Trinity
JoeySnaps
Enthusiast
I don't have this particular lens, but I think that's normal. The ring isn't mechanically linked to the focus mechanism. Rotating the ring triggers sensors which pass the instruction to the focus motors to move the lens elements. So there's no end stop to the ring's travel. I think it's known as focus-by-wire.
R6mkII, various lenses, speedlites. Also legacy Canons going back to T90 and even A1.
14 REPLIES 14
JoeySnaps
Enthusiast
I believe the EF lenses, which have eight electrical contacts with the camera, are not able to convey focus position information to the RF camera through the EF-RF adapter. The RF mount has twelve electrical contacts.
@enriquehoja.  Are you using a Canon Brand Control Ring or adapter?  I have this lens, but have never tried it on my MILC body.  @JoeySnaps also made a good point.
jaewoosong
Rising Star
Rising Star
-jaewoo
Thanks for answering @Jaewoo. Could you tell me if the focus ring on your 16-35 stops rotating at the infinity and zero sides?
Yes Canon EOS EF-R
The focus ring on this lens shouldn't rotate while AF is being performed. There is a clutch under the focus ring to allow for manual focus override. The focus scale Will move though. You should be able to turn the focus from 0-Infinity.
-Demetrius
-Demetrius
I mean, when in MF, this ring rotates 360 degrees (it doesn't stop on either end) and I suspect it is broken, but it does stop focusing more after infinity (the ring just keeps moving).
-Demetrius
-Demetrius
JoeySnaps
Enthusiast
Friends and Family
