EF 100-400mm f/4.5-5.6L IS II USM compatibility with EOS R7
libbysmith
does the canon lense 100-40mm f4.-5.6L Is II USM fits on a canon R7?
Thank you
2 REPLIES 2
March411
Hey libbysmith,
That lens will function on your R7 but you will need to purchase a Mount Adapter EF-EOS R. It is best to use the original Canon adapter as third party adapters have reported issues such as lens racking and battery drain while the camera is off. New they are around $150 but you can find them used at several Canon authorized sellers.
EF Lenses supporting maximum continuous shooting speed
EF24mm f/2.8 IS USM EF400mm f/2.8L IS II USM EF24-105mm f/3.5-5.6 IS STM EF200-400mm f/4L IS USM Extender 1.4x
EF28mm f/2.8 IS USM EF400mm f/2.8L IS III USM EF24-105mm f/4L IS II USM EF-S24mm f/2.8 STM
EF35mm f/1.4L II USM EF400mm f/4 DO IS II USM EF24-70mm f/2.8L II USM EF-S35mm f/2.8 Macro IS STM
EF35mm f/2 IS USM EF500mm f/4L IS II USM EF24-70mm f/4L IS USM EF-S10-18mm f/4.5-5.6 IS STM
EF40mm f/2.8 STM EF600mm f/4L IS II USM EF70-200mm f/2.8L IS II USM EF-S18-55mm f/3.5-5.6 IS STM
EF50mm f/1.8 STM EF600mm f/4L IS III USM EF70-200mm f/2.8L IS III USM EF-S18-55mm f/4-5.6 IS STM
EF85mm f/1.4L IS USM EF8-15mm f/4L Fisheye USM EF70-200mm f/4L IS II USM EF-S18-135mm f/3.5-5.6 IS USM
EF100mm f/2.8L Macro IS USM EF11-24mm f/4L USM EF70-300mm f/4-5.6 IS II USM EF-S18-135mm f/3.5-5.6 IS STM
EF300mm f/2.8L IS II USM EF16-35mm f/2.8L III USM EF70-300mm f/4-5.6L IS USM EF-S55-250mm f/4-5.6 IS STM
  EF16-35mm f/4L IS USM EF100-400mm f/4.5-5.6L IS II USM
https://cam.start.canon/en/H001/supplement_0080.html
Here is a link to the Canon website for the Mount Adapter EF-EOS R - $150
Marc
Windy City
To find common ground you must be willing to search for it.
Our interests intersect more than they diverge.
R5 Mk II ~ R6 Mk III ~ R7
Lenses: RF Trinity and others
Personal Gallery
deebatman316
Hi @libbysmith welcome to the forums. The lens is designed for DSLR cameras. It cannot be directly mounted to your camera. It’s a Mirrorless camera and to use older EF lenses. You must use a mount adapter. As my colleague @March411 pointed out to stick with the Canon brand adapter. 3rd Party adapters cause all sorts of problems. Also not every feature in EOS R series cameras will be supported with adapted EF lenses. Canon however does make an RF equivalent of that lens which is the RF 100-400mm f/5.6-8 IS USM lens. Which doesn’t require the adapter to work.
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF F/2.8 Holy Trinity
