09-23-2013 03:04 PM
Do you use the 100-400mm in combination with 2x extender ? What do you think about this combination ?
04-21-2018 12:16 PM
@GeorgeMwrote:I must be doing something wrong. I have “live view” enabled in my EOS 70D and the switch on the back of the camera is set to live view. I am using a 2x ii extender. Autofocus will not work. When I try to focus on an object, the f stop setting is flashing on the display. Any suggestions?
What shooting mode are you using. Try using M mode. How many focus points are you using? Use just the center one in the viewfinder, and then try Live View, although I do not think that will really help.
The minimum aperture is probably too high. With the adapter, you will get a minimum range of f/8-11. You say the f/stop is flashing. What value of f/stop is it displaying as it flashes?
The EF 2x models are not recommended for use with lenses with minimum apertures exceeding f/4. The extender instruction manual can tell you which combinations of lenses it is compatible with. You camera instruction manual should tell you which focus points would be available, which in this case I would expect none to be available in the viewfinder.
09-23-2013 03:28 PM
No.
It is technically compatible, but not very practical. A 2x extender doubles the focal length AND the focal ratio. An f/5.6 lens becomes an f/11 lens and no camera can auto-focus at f/11. Very few cameras can auto-focus at f/8.
Typically only an f/2.8 lens is appropriate for use with a 2x adapter (because they become f/5.6 lenses when they're on the adapter.)
The manual (which you can download) contains the list of compatible lenses.
See: http://gdlp01.c-wss.com/gds/8/0300004658/01/extender-ef-2x-iii-en.pdf
09-23-2013 03:38 PM
I know it's tempting to go for an impressive 200 - 800 mm focal length setup, but if it didn't have its drawbacks everyone would own this combination (and Canon wouldn't be able to sell the new 200 - 400 1.4X for $10,000+).
Although they increase your focal length, extenders also 1) cut out the amount of light, 2) compromise image quality. The first point has the added complication that it can affect autofocus. All cameras have a minimum aperture size that it needs for autofocus to work, most are around f5.6, some high-end cameras go up to f8. The 2X will move up the largest aperture size of the lens two stops. So the 100 – 400 f4 – 5.6 will become a f8 – f11. Even high end cameras will probably struggle once zoomed much past 100mm.
You’re most likely not going to have auto-focus, so how do you feel about using manual focus only? The 2X will also compromise sharpness a bit, so you’ll probably have to stop down the lens quite a bit to get a result you like (plus the extender cuts out 2 stops). It’s fine if you have enough light, but it’s going to cut into your flexibility.
09-24-2013 10:37 AM - edited 08-08-2015 01:57 PM
I use the 100-400mm f4.5-5.6 a lot. It isn't that sharp of lens in the first place to cripple it in any way. So a tele adapter is out of the question, even the 1.4x.
The best it gets is to use it with a Canon7D and take advantage of the 1.6 crop factor.
Oh, and BTW, the 100-400mm is a f4.5 not a f4. Unless Canon has come out with a later version.
04-28-2014 06:49 AM - edited 04-28-2014 06:52 AM
Hi, I have just purchased a Canon EF 2X III teleconverter, it's between a Canon 70D and a Canon EF 100-400mm IS-L USM lens. The TTL auto focus does not function, BUT, with the ground breaking dual pixel CMOS in the Canon 70D, I can use the lens's auto focus in LIVE VIEW. The length and weight of this combination means no hand held, tripod only. I use a stylus, as for an iPad etc, to chose the focus point on the LCD screen in live view, and the new auto focus system instantly focuses on that spot. I am getting results at 800mm (1280mm with 1.6 crop factor of the smaller sensor), that are, I think sharper than hand held at 400mm (640mm) with the lens only.
So, to those blogs I read that say the Canon teleconverter stops auto focus, look again with a 70D in live view!!
When the high end cameras recieve this new dual pixel sensor technology, the teleconverters will be very useful.
04-28-2014 08:40 AM - edited 04-28-2014 08:40 AM
" I am getting results at 800mm (1280mm with 1.6 crop factor of the smaller sensor), that are, I think sharper than hand held at 400mm (640mm) with the lens only."
08-08-2015 11:11 AM
MickvK,
Now that you have had the combination of the EF 2X III teleconverter with the EF 100-400mm IS-L USM lens and 70D for more than a year do you still think it was worth it?
In particular, if you tripod mount the lens both with and without the teleconverter, and compare the quality of the photos blown up to full pixel resolution, how good does it look. Is it still worth the investment to get the extender considering that you will need to bump up the ISO to get the same shutter speed (adding noise) or reduce the shutter speed to keep the same ISO (adding the potential for image movement).
I currently have the combo of EF 100-400mm IS-L USM lens and 70D that I use for wildlife photography (with a tripod). Adding a 2X teleconverter is tempting but if it reduces the quality to what I'd get hand holding the lens then its a poor investment for me.
09-03-2015 10:56 AM - edited 09-03-2015 10:58 AM
I ended up buying both the 2x extender and new 100-400 lens and it turned out to be a good decision. In short, the image stabilization on the mark II lens is indeed amazing even with the 2x extender and well worth the investment.
I had read numerous online posts from "experts" that an extender will make the images look soft and that you will lose contrast. "They" also said you could get just as good a result by not using the extender and blowing up your images by 2x. I decided to put this to the test. I want to be able to take wildlife headshots that show whisker detail from far enough away that there's no danger of getting my face ripped off or getting gored. So I set up a resolution test chart 75 yards away in a somewhat open forest that had dappled light, probably the worst conditions that I could expect to be successful in. I then took multiple photos and varied the following: Old and new lens, no extender, 1.4x and 2x extenders, f stop, ISO, tripod vs. hand held. Shutter speeds were slow at reasonable ISO settings due to the light and gave a good test of real world conditions. I found the following:
1.Mounted on a secure tripod and without an extender both the old and new lens gave approximately the same maximum resolution (about 12 lines per inch) at 75 yards, the resolution limit is driven by the number of pixels in the camera, not the lens.
2. When using the extender, even when mounted on a tripod, you will need to set the shutter to high speed continuous and take 4 to 6 images so that you get at least a couple good images. Breezes and shutter vibration will cause some movement during exposure.
3. The 2x extender was more useful than the 1.4x extender. With a 1.4x extender and the lens set to 400mm, I could resolve about 20 lines per inch, with the 2x I could get up to about 25 lines per inch when mounted on a tripod.
4. The real difference between the two lenses is the image stabilization. A hand held shot with the old lens at 800mm was laughable; it was just one big blur. The image stabilization with the new lens makes hand held shots possible if you are leaning against a support with your elbows tucked in and control your breathing (or rest the lens on support). You will need to set the shutter to high speed continuous and take 5 to 10 images. I got about 50% that looked at least OK and about 20% that were really good even with shutter speed under 1/100.
Here is a jpg copy of a test shot I did handheld. It’s lost some resolution in the jpg conversion process but you can get the idea. This was the best of a half dozen images and was shot at 1/50, f11, ISO 320. The target is 20” across so you can think of it as a head shot of a mountain goat or grizzly bear. It’s good enough for printing to 8x10 or smaller or for use on the web. I found the best tradeoff of ISO, f stop, and shutter speed at 800mm to be ISO 320, f11, and as fast a speed as lighting will permit. That was true whether handheld or using a tripod.
As you can tell from the resolution chart, I won't be getting any bear photos showing whisker detail any time soon, even 25 lines per inch won't capture that.
09-11-2015 02:55 AM
Thanks for the interesting post ParadisePhil.
Why aren't you shooting faster shutter speeds handheld? I was taught to double my focal length to get a shutter speed that will be sharp when shooting handheld.
Am I correct in that auto focus with the 2x extender will work with the 100-400 non IS but will not with the IS version? (I have the 100-400 IS i).
Also, some within this thread said that auto focus at F8 does not work. I used my 100-400 IS @ F8 to shoot surfing photos recently and didn't have a problem with auto focus, my body is a 6D.
Thanks
Jason
09-11-2015 05:04 AM
ParadisePhil, to be honest I got tired of having to cart the 2X converter, tripod etc and I bought a 7D MKII which doesn't have the versitile swivel, touch screen. The 70D has been relagated to my 24-105 USM lens. I'd love to buy the new 100-400 USM II lens, it sounds great. Oh the cost of a hobby!
Happy shooting mate. Michael.
