02-25-2020 08:18 AM - edited 02-25-2020 08:26 AM
Hi all,
I have a Canon EOS M50. I just bought a multi adaptor and the EFS 24mm f2.8 lens because I want a wider angle and lower F stop. But it seems like the 24mm f 2.8 is not too different compared to the kit lens 15-45mm 3.5-6.3.
1. ) What is the most useful and effective wide-angle lens with a lower f stop or the EOs M50 for night photography? it seems the wide-angle EFS 24mm f2.8 lens works better on a full-frame.
02-25-2020 08:21 PM
Impressive!!! Thanks a lot. Was trying to make up my mind. I ended up buying it today
07-03-2020 08:51 AM
07-03-2020 01:03 PM
@icycreative wrote:
Hello guys... so I’m new to mirrorless cameras I know quite about filmmaking and photography but this m50 is my first beginner pro camera... so my concern... is when I was in 4K in video mode... I saw horizontal lines like shades lines banding across the screen... only in 4K... and only with a certain tungsten bulb on... I read that certain light frequencies can cause this with shutter speed? And MAIN thing... when I take pics in auto mode it seems to lag like 2-3 seconds after I click the shutter after it focuses and it takes so long for the Image to preview and to try to take another pic right after... now I was trying this in very low blue led light... haven’t tried in the sun yet... I read maybe I have a preview feature 2 second turned on that if I turn off it will help? Just wondering if this is all normal... cuz my canon point and shoot seems SO quick! But probably cus it’s not as complex ?
You should start a new thread for your issue. Try resetting your camera back to factory defaults with the camera P mode. If this does not fix your problem, then I suggest that you either Contact Canon support, or start a new thread of your own.
