printer auto on function
Rustygun
How can I enable the Auto-on function  with my TS 6320 printer when data is received via wireless ,  or override the auto off function after a period of idol time?
4 REPLIES 4
Rustygun
how can I enable my printer (Cannon TS6320) to auto on when it receives data. Or disable the auto off mode?
Hi Rustygun,
To access the power settings of your PIXMA TS6320, please follow the steps provided for ECO settings in the manual, using the following link:
http://gdlp01.c-wss.com/gds/8/0300036828/01/TS6300ser_OnlineManual_Win_EN_V01.pdf
what are ECO settings ?   Sorry for the confusion Danny
OK found it Thank You.  page 199
ECO settings
This setting allows you to use automatic duplex printing as a default to save paper and to turn on/off the
printer automatically to save electricity.
Using Power Saving Function
Using Duplex Printing
Follow the procedure below to use power saving function.
1. Check that printer is turned on.
2. Press the OK button.
3. Select Device settings.
4. Select Other device settings.
5. Select ECO settings.
6. Select Energy saving settings.
7. Specify settings as necessary.
A: Specify the length of time to turn the printer off automatically when no operation is made or no
printing data is sent to the printer.
B: Selecting ON enables the printer to turn on automatically when a scanning command from a
computer or printing data is sent to the printer.
