01-12-2021 09:00 PM
Hi, my Pixma G7020 is dead, no longer turns on, I had tried plug in another power outlet in another room, connected to another laptop, but still doesnot help.
Can any technical support here help me replace it?
I work from home, so I need this fix as soon as possible
Thank you
01-14-2021 04:06 PM
Please make sure you're filling in all the required blanks with the correct information to submit your completed registration. Without that, you won't be able to get through to our support agents. We need to have your registration on file for you to get access to a support agent, and you'll also want to make sure you're calling from the number on your registration.
You may also want to try using a different browser if you continue to encounter registration problems.
We look forward to your call!
01-13-2021 09:32 AM
The quickest way to get a replacement is Costco, BestBuy, Staple, Office Depot... whichever is closest to you.
If the printer is still under warranty, Canon may consider replacing it for you, but you will need to open a support case and wait for a determination.
If getting up and running is paramount, buying what you need will be the fastest soluton.
01-13-2021 05:08 PM
thank Shadowsports,
yes, the printer still under warranty, How do I open a support case?
Do you have email or a link that I can reach to a real person? I called in, but the caller-robot keep turn me around.
01-14-2021 06:24 AM
To use email, follow this link and select My Support Account below:
Canon U.S.A., Inc. | Service & Repair
01-14-2021 08:15 AM
Hi, quoctruong! To get support by phone for your PIXMA G7020, you'll need to register your printer first. Once you've done that, our caller ID system will recognize you when you call in and you'll be able to get through to a support team member. Registering is quick and easy, so click HERE to get it done.
Hope this helps!
01-14-2021 03:57 PM
01-14-2021 03:59 PM
01-14-2021 04:06 PM
01-14-2021 07:34 PM
12-04-2021 07:08 AM
Shame on Canon for such shoddy customer service! I know the pandemic creates problems, but that amount of time and that many interruptions just seems a teeny bit over the top for acceptability.
