04-30-2020 12:12 PM
Have a TR8520 printer and a computer OS of the latest Ubuntu Linux. Had been using the printer with Windows wirelss driver, but I only use the printer every now and then, so it simply stopped working after awhile (no error message, the compute went through its routine and announed I had successfully prited a page while nothing actually printed). So I hoked up my Linux computer to the printer with a wire and downloaded cnijfilter2-source-5.50-1.tar.gz, but then get an error message when I try to install it! TAR.GZ files are what my computer usually uses. Is there any way to get an update to that file?
05-01-2020 09:43 AM - edited 05-01-2020 09:50 AM
Telling us you get an error messgae witout providing the actual error doesn't give us much to go on.
Downloads for the TS8520 (including linux) are here:
It looks like Canon has tested the driver you tried above with Ubuntu 17.04. Current version is 20.4 LTS Other packages may or may not work. Not sure if the file you have or downloaded is corrupt or if there is another problem, but re-downloading a fresh copy of the file is a good place to start.
05-01-2020 06:06 PM
Hmm. Yeah. Got same error. The idea that it may work for an older version of Linux makes more sense than the idea that it never worked at all.
Would love to provide more details as to error messages, but the program for the printer doesn't provide anything.
