01-10-2020 05:33 PM
I have had this printer for a few years with minimal problems. But, now the PGBK250 ink cartridge will not print. When I print a normal b/w page I get nothing. For a while I was getting a light blur of the text, now I am getting nothing. I have tried to clean printheads, and the deep clean printheads commands. Following which I print a print head alignment sheet, but there is no print coming from the pgbk printhead.
01-11-2020 09:43 AM
Straight from Canon:
When inks do not print correctly, we recommend performing at least one cleaning and two deep cleanings on the unit as you have done to try and get the ink to print. If the ink still does not print, and removing the print head and ink tanks in the unit, as well as replacing the ink with new ink tanks does not resolve the issue, the printer may require servicing. We ask that you please contact Canon technical support for further assistance.
What I suggest. Remove the ink taks and printhead (inspect and clean). If used infrequently, it might be clogged.
Print heads have a useable life.
01-11-2020 01:01 PM
Thank you for your response. I am a detail person, so I have no issues trying my hand to remove the printheads. Where do I find instructions on how to remove the printheads of my Pixma MG7120?
01-13-2020 02:58 PM
Hi Rwhale,
To reseat the printhead, please follow the steps in this Knowledgebase Article:
https://support.usa.canon.com/kb/index?page=content&id=ART141309
01-15-2020 06:43 PM
I have done a water bath of the printhead, and the PGBK still does not print all the other colors perform beautifully. So maybe it is time to replace the printhead assembly. What does itis the cost for a replacement printhead for the Pixma MG7120? Do I order it through Canon or are they available through 3rd party?
01-16-2020 03:11 PM
Hello.
If the issue persists after cleanings have been done, the printer may need to be repaired. It would be best to check your local listings for any repair shops that might be able to examine the unit. However, if you wanted to check on the availability of a print head, call our Sales department at 1-800-385-2155.
