03-25-2024
07:56 AM
09:26 AM
Is the TS5352a, updated with the latest firmware, compatible with WPA3 Personal? Or only WPA2?
03-25-2024 11:02 AM - edited 03-25-2024 11:03 AM
The printer is compatible with a 2.4Ghz broadcast using WPA2 / AES Encryption.
If your router has a setting for WPA3 / WPA2 like mine, you can use that setting. If it doesn't offer both, then select WPA2
03-25-2024 08:35 AM
Hi there!
That unit isn't sold or supported by Canon USA. You'll have to reach out to Canon in your area for more information.
Get started at https://canon.global
