PIXMA TS5120 Error code 5100
gerty95
I have the Canon Pixma TS5120
It is showing the error code 5100 which says it is for a paper jam or ink cartridges
There is no paper jam and the paper flows from the top out the bottom when it is turned on
The Cartridges appear to be put in fine.
Is there any other issue this could be or a way to override the error code?
1 REPLY 1
Patrick
Hi gerty95,
The 5100 error can be caused by a paper jam.  I understand that you have checked for this, but please use the links below to make sure all areas have been checked:
TS5120 - Paper Is Jammed inside Printer
TS5120 - Removing Jammed Paper from Rear Side
The 5100 error can also be caused by a smudge on the encoder/timing strip.  Please follow the steps in this Knowledgebase Article to clean the encoder/timing strip:
Cleaning the Encoder (Timing) Strip - TS5120
If the 5100 error persists, your PIXMA TS5120 would require service.  If your PIXMA TS5120 was purchased less than a year ago, please contact one of Canon's Technical Support Representatives via phone or chat to obtain your in warranty options. To contact a Technical Support Representative, please use the link below to log into your My Canon account:
https://mycanon.usa.canon.com
Once logged in, click on your PIXMA TS5120 and then click on the Product Support button.  When that page loads, click on either the Phone Support button or the Chat Support button to access support.
If your PIXMA TS5120 is out of warranty, you are eligible for Canon's Upgrade Program. This is for out of warranty units which have been diagnosed to require service, or for some reason are incompatible with a new or upgraded system. This option allows you a one-time opportunity to purchase a replacement product, discounted from the list price.
If you would like to take part in this option, please call our Sales Department at (866) 443-8002 Monday through Saturday, 9am to 9pm. Let them know you have been working with technical support and the Canon Upgrade Program was offered.
Friends and Family
