10-21-2015 05:09 PM
10-29-2015 12:01 PM
After the note from JohnnyRow I decided to uninstall the printer software, reinstall and ensure I had latest driver since I originally got the printer under Windows 7, then went to 8, and now 10. After reinstall noted that the software still assigned to Drive J: and the notices to insert a disk into J: kept coming. As JohnnyRow suggested I changed it to P: It's only been three days but yet have had the notice and I was getting the notice a couple dozen times a day, so am keeping my fingers crossed. Thanks again JohnnyRow!!!
10-25-2015 12:07 PM
I had a similar problem on a different Canon printer. After much trouble, I eventually fixed it. It had to do with the printer having a slot for removable USB memory stick. I changed the default drive assignment for the printer slot from L to P and problem solved. I don't remember the exact details but it had to be a higher drive letter than some others. I think it was it searches through the successive drive letters and gets upset when there is an empty drive. There is some situation that makes it stop the drive search, maybe when it comes to the first non-assigned drive. I just made my drive assignment near the end of the alphabet and it worked.
10-26-2015 09:47 AM
Thank you JohnnyRow!! I will give that a try.
10-29-2015 12:01 PM
