MP160
CharlesC
Printer has started to print a blank page each time i print.  I've turned the power off and on.  Same problem.
1 REPLY 1
Patrick
Hi CharlesC,
When your PIXMA MP160 does not print as expected, please remove both ink cartridges from the printer and make sure that the orange tape has been removed.
Next, please reinsert the ink cartridges and please perform 2 printhead cleanings:
 1.  Ensure that the printer is powered on and the LED displays a 1.
 2.  Press the <Maintenance> button once to display [H].  The Maintenance button is the button on the left hand side of the Operator's panel which has the wrench and screwdriver label above it.
 3.  Press the Black Start button. The cleaning will commence.
After performing 2 cleanings, please attmept to print.
If the issue persists, it is recommended that the ink cartridge is replaced.
Friends and Family
