MG 5220 error code
lpmullins
Hello.  I have a Canon MG 5220, and it just gave a message, "B200 Printer error has occurred.  Unplug the power cord and contact the service center."
Where is the "service center" and how do I contact it?
Or can anyone here give me a clue as to what the error code means and what to do?  In the meantime, the printer won't do anything.
Thank you.
Patrick
Hi ipmullins,
It is recommended that you contact one of Canon's Technical Support Representatives. To contact a Technical Support Representative, please use the link below:
http://Canon.us/ContactLI
6 REPLIES 6
Patrick
Hi ipmullins,
Thank you for the Canon contact info, Patrick!
I would contact them, but they require the serial number and date of purchase.  I could get the serial number off of the machine, I'm sure, but I have no idea when it was purchased. We have had it for several years.  At this point, I don't think it's worth the hassle and much easier and probably cheaper to just buy a new printer copier scanner.
aflamingo
try reloading the printer driver.  it may take more than one try
Thank you, aflamingo!
How do I reload the printer driver?
Hi, AdhamTB!
Welcome to The Canon Community, and thank you for your inquiry!
We appreciate your participation, however, we need to let you know that the Canon Community is hosted and moderated within the United States by Canon USA. We are only able to provide support for Canon products manufactured for and used within the US market.
If you live outside the United States, please CLICK HERE and select your country or region for your support needs.
You're welcome to discuss Canon products sold outside of the United States, but please be aware that you will not receive support directly from Canon USA.
Canyonator19
I have the same problem, Error Code200, and when I try to download the drivers it cannot connect to the printer since the Yellow light is flashing.  I've tried it numerous times after unplugging both the power and the USB connector from the compouter.
The troubleshooting solutions talk about removing the printhead and rinsing it out then attempting to print after it dries.
Tried to do this but could not see how the printhead was to be removed after I took out the 5 cartridges.
