11-15-2017 10:42 AM
Hello, I'm hoping someone can assist.
I recently upgratded the OS on my iMac to mac OS High Sierra Version 10.13.1. I've noticed the scanner function on my MX870 (connected via wireless) will not operate. When I click on Scan/Import photos or documents in the Canon Solutions Menu, I see the scanner icon bouncing in the tool bar at the bottom, then it disappears and I get the folowing error message:
MP Navigator EX quit unexpectedly.
Click Reopen to open the application again. Click Report to see more detailed information and send a report to Apple.
I'm not sure if this helps, but this is the first section of the report the system sends to Apple when the issue is encountered:
Process: MP Navigator EX 3.1 [3067]
Path: /Applications/Canon Utilities/MP Navigator EX 3.1.app/Contents/MacOS/MP Navigator EX 3.1
Identifier: jp.co.canon.bj.printer.app.MPNEX310
Version: Version 3.1.0 (3.1.0)
Build Info: MP Navigator EX 3.1-1~1
Code Type: X86 (Native)
Parent Process: ??? [1]
Responsible: MP Navigator EX 3.1 [3067]
User ID: 501
Date/Time: 2017-11-15 07:39:45.325 -0800
OS Version: Mac OS X 10.13.1 (17B48)
Report Version: 12
Anonymous UUID: A53C885F-95A1-3111-2313-9C7D531A0D71
What I've tried so far:
- Serached the Canon website for updated drivers or firmware but it says everything is up to date
- Powered the unit off/on
- Unplugged the unti for a minute, plugged it back in
11-15-2017 12:09 PM
Hi rexus31
At this time Canon has not released Mac OSX 10.13 drivers for the PIXMA MX870. All updated Drivers will be posted to Canon website at www.usa.canon.com as soon as they become available. Currently, we do not have any information as to when or if these drivers will be available.
10.13 uses Airprint, any unit that is Airprint compatible can print as long as you are connected wireless Note: Airprint does not support scanning.
If you continue to have difficulties or need further assistance, please contact our support group using the following link:
http://Canon.us/ContactLI
11-15-2017 12:14 PM
So what is my solutiuon? Purchase a newer printer/scanner? In browsing through this forum, it appears other Mac users are in the same boat.
11-24-2017 10:11 PM
Im in Australia. I have MX870, I installed Sierra High Update, noticed a few days after than I could not scan. I am sure I could print okay, but I have 2 multifunction centres attached to my Mac and I have no set pattern for which one I use. I was on a deadline to scan and send an email . I phoned Canon in the Phillipines (Canon Support for Australia) and they said there were no updated drivers. This was at 17 November 2017. The only thing I could do was get Mac to talk me through downgrading to first version of Sierra. Luckily I had backups with timemachine - I went back to first version of Sierra. The only thing I did not realise is that when you use timemachine, it can take a long time for your Mac to get the info, in my case, it was 4 hours which was about 250 gb of hard drive.
So about 8 hours wasted in all.
Dont know whether Canon will update drivers, probably trying to force you to update to another one of their machines..
I love the MX870 for scanning!!!! and machine is a few years old, but I will keep it until it dies, despite me having a 2nd office led printer/scanner. 24 November 2017 -
11-27-2017 11:21 AM
Just had a very helpful session with the Canon administrator. He walked me through re-installing software from OS 10.11 and the scanner is working again. He recommended folks call Canon assistance with this.
11-29-2017 02:00 PM - edited 11-29-2017 02:01 PM
The scanner didn't work for me either once I've updated to High Sierra and doesn't look like Canon will be providing a new driver for the update.
I've called them and they've suggested I use Mac's Image Capture application to scan. This works for me.
12-02-2017 05:06 PM
I have the CanoScan LiDE700F and this is the second Canon scanner that has become worthless when we can no longer get Canon driver updates.
I did use PDFScanner, which may be an app that comes on the Mac that I could use to do some basic scanning.
12-18-2017 10:56 AM
I have had the same problem with an MG8120B - priniter works but scanner does not.
12-22-2017 12:32 AM
Same problem here. Solved by using scanner functionality in System Preferences/Printers & Scanners/Scan. Not as easy to use as the Solution Menu, but it does the trick
01-03-2018 05:45 PM
Thank you for this! This worked for me. I dragged the old MP Navigator installation to the trash. I redownloaded the version for 10.11 and reinstalled it, and I am back up and scanning.
