Canon MG 8120 - Scanner does not work anymore
wytanaka
Have an MG8120.  Using Window 7.  Had problems with my wireless network (in my home), so I had to set up the network all over again.  Then I installed the latest printer driver and reconnected printer to my wireless network. The printer works fine.  The scanner does not respond.  Diagnostics say there is nothing wrong.  The printer and scanner were working fine before I had to reconnect to the network.  Any ideas?
1 REPLY 1
Patrick
Hi wytanaka,
Uninstalling and reinstalling the network port and printer driver should resolve this issue.  To perform the uninstall, please have the PIXMA MG8120's CDROM in the CDROM drive and then follow these steps:
 1.  Click on Start and then Run.  If Run is not in your Start menu, please follow these steps to add it:
     1-1.  Click Start.
     1-2.  Right click the Start menu and left click on Properties.
     1-3.  Click on the Customize button next to 'Start Menu'.
     1-4.  In the Customize Start Menu window, place a checkmark next to 'Run Command'.
     1-5.  Click OK in the Customize Start Menu window.
     1-6.  Click OK in the Properties window.
 2.  Click Browse.  In the Browse window, click on "Computer".
 3.  Double click the CANON_IJ CDROM.
 4.  Double click the folder named WIN.
 5.  Double click the folder named Driver.
 6   Double click the folder named DrvSetup.
 7.  Double click the file named DELDRV.  If you are using the 64 bit version of Windows 7, please double click DELDRV64.  In the Run box click OK.
 8.  Click Execute to start uninstall and Yes to completely uninstall the drivers.
 9.  Once finished, click on Start and then Run.
10.  Click Browse. In the Browse window, click on "Computer".
11.  Double click the CANON_IJ CDROM.
12.  Double click the folder named WIN.
13.  Double click the folder named Driver.
14.  Double click the folder named LAN.
15.  Double click the file named CNMNPU.exe
16.  In the Run box click OK and then Yes on the Delete BJNP Port window.
17.  The uninstaller will prompt you to restart the computer, please click Yes to restart the computer.
To install the unit for use over your network wirelessly, please follow these steps when the computer restarts:
 1.  Use the up or down button on your PIXMA MG8120 to display Setup and press the right FUNCTION button.
 2.  Select Wireless LAN Setup and press OK.
 3.  Select Yes and press OK.
 4.  Select Easy Setup and press OK.
 5.  Select your access point name and choose OK.
 6.  Press the right FUNCTION button on the Enter passphrase or Enter WEP screen.
 7.  Enter your WEP or passphrase and press OK.
 8.  Make sure network key is correct and press OK.
 9.  When the connection confirmation appears, press OK.
10.  Take out and then reinsert the CDROM that came with the PIXMA MG8120.  The setup program will start automatically.  If the Autoplay screen appears, click Run and then Continue.
11.  Click on Easy Install.
12.  When the Easy Install screen appears, click Install.
13.  Select Use the Printer on Network and click Next.
14.  If it appears, please read the License Agreement carefully and click Yes if you agree.
15.  Click Next at the Printer Detection screen.
16.  Select PIXMA MG8100 Series in the Detected Printers List and click Next.
17.  On the Canon IJ Network Tool screen, select the PIXMA MG8120 and click Next.
18.  Confirm the results and then click Finish to complete the installation.
Once reinstalled, please attempt to scan.
If you continue to have difficulties, please contact our support group using the following link:
http://www.usa.canon.com/cusa/consumer/standard_display/contact_us_consumer
