05-24-2022 06:34 AM
I have had my camera for a few months and have loved it so far. The EOS utility seems to consistently fight me. Numerous times the utility has decided it didn't recognize my camera. This was normally rectified with a restart of the computer, camera, or both. Starting yesterday it wont recognize my T7i no matter what I have tried. Different ports, different cables, uninstall/reinstall EOS utility, un/reinstall drivers. I am at a loss. Anyone have any thoughts on how to fix it or have an alternative for the image transfering process? When it works it is great for organizing photos as they come in the my PC. When it works....
I can run the .EXE for EOSv.3 and it worked fine. It is supposed to auto start when plugging in the camera via USB. That didn't happen for some reason....
05-24-2022 07:56 AM
Just use a card reader and bypass EOS Utility completely. On a Mac, it is not necessary at all.
05-24-2022 12:45 PM - edited 05-24-2022 12:47 PM
If you told Windows to launch the EOS Utility when it detects that camera has been connected to the USB port, then could be the problem.
When EOS Utility software is installed, a separate EOS Launcher Service is also installed. This is the camera icon that you see on the lower right near the clock. If you right-click on the icon, you can set the startup options when the camera is connected to the USB port.
[EDIT] Windows needs to be set to take no action.
05-26-2022 10:18 PM
What version of EOS Utility are you using? The T7i requires EOS Utility 3.
