06-05-2020 09:31 AM
Eos Utility (euw3.12.10-installer)
Does Not launch Eos Utility 3
when i connect my 6D or 80D windows is reporting the connection .
But Eos Utility does not respond in any way.
W10 V1909
Troubles startet after the w10 update or EU update, I can't tell.
I don't have AVG so don't bother mentioning.
06-09-2020 07:33 AM
EOS Utility 3, when started manually is working like it should.
It transfers files and allow for manipulation of the camara settings.
2 differnt cables, 2 different ports.
No difference noticable
cpu intel Core i7 8700K
Northbridge Intel Coffee Lake rev. 07
Southbridge Intel Z370 rev. 00
Memory Size 32 GBytes DDR4-3200
Mainboard Model Z370 AORUS Gaming 7
GPU GTX1070
No brand. Own build.
(Running for aprox. 2years now)
06-09-2020 09:42 AM
People with home brewed machines always have quirky issues. Most of the time it is related to USB port hardware and drivers, most especially those who are running AMD chipsets.
Canon does not recommend USB port expanders, and discourages their use. Are there any USB ports, perhaps on the rear, that connect directly to the motherboard? Did you try one of those? A recent user found that to be a solution.
06-09-2020 10:06 AM
The camera responce does not change when i use a rear panel USB port.
The Machine has been working flawlessly with canon software upto a month ago.
It is 100% sure not the machine.
If you ask me the service canon wrote is outdated by the W10 1909 updates.
Microsoft is a very unreliable partner. Rejecting working drivers or services just to piss us off is unforgivable.
This is not the first package wich collapses under the wild reckless update strategy of W10
Maybe the MOBO needs a software update or maybe i shouldn't have updated the MOBO at all.
The Dell Laptop i use is the same unreliable house of cards as my home brew PC.
on any given day software may stop working because MS decides to stop accepting the drivers.
It happens on a regular base because my job havely leans on USB tools.
I do understand Canon does not like USB expanders. It is a house of cards. Fitting Displayport into the USB-C protocol does have its risks towards the rest of the lot.
