Digital Photo Professional 4.11 Can't Convert and Save
Andy4
I am using DPP 4.11 and trying to convert and save a RAW file to a JPG file.  The software doesn't seem to work. the pop-up window apears, I press save and pop-up window goes away but no file is saved.
I am using MacOS Catalina 10.15.
When I save the RAW file with edits. opening the file in Preview or Photos in the MacOS i only see the orginal RAW file and not the edits. only see the edits in DPP
AndyP
15 REPLIES 15
Help
I tried Batch processing which seemed to work and create a .JPG file.
However the files created can't be opened or worked on.
Hey there,
What program are you trying to open it in, and where in your computer are the JPEG files being saved?
Trieu
Me too
Hi Everyone
I upgraded to Version 4.11.1
Convert and save...  working for me to convert to jpg
Batch process...  working for me to convert to jpg
i have no problems opening and editing the saved jpg's in other programs.  ie Photos, Affinity
thanks
What is the Batch Process? I can't save into jpg too, using Catalina.
Many thanks,
Maya
Many thanks,
Maya
For whatever set of reasons, DPP will not overwrite files when you create output JPGs.  The Batch Processs is best explained by trying it.  Select two or more files, then select the Batch Process in the Files menu.
