10-30-2019 03:35 AM
I am using DPP 4.11 and trying to convert and save a RAW file to a JPG file. The software doesn't seem to work. the pop-up window apears, I press save and pop-up window goes away but no file is saved.
I am using MacOS Catalina 10.15.
When I save the RAW file with edits. opening the file in Preview or Photos in the MacOS i only see the orginal RAW file and not the edits. only see the edits in DPP
AndyP
12-07-2019 04:39 AM
Help
I tried Batch processing which seemed to work and create a .JPG file.
However the files created can't be opened or worked on.
12-12-2019 03:00 AM
Hey there,
What program are you trying to open it in, and where in your computer are the JPEG files being saved?
12-15-2019 07:18 PM
Me too
12-16-2019 08:21 AM
Hi Everyone
I upgraded to Version 4.11.1
Convert and save... working for me to convert to jpg
Batch process... working for me to convert to jpg
i have no problems opening and editing the saved jpg's in other programs. ie Photos, Affinity
thanks
04-20-2020 01:42 PM
What is the Batch Process? I can't save into jpg too, using Catalina.
Many thanks,
Maya
04-20-2020 02:28 PM
@maya123 wrote:What is the Batch Process? I can't save into jpg too, using Catalina.
Many thanks,
Maya
For whatever set of reasons, DPP will not overwrite files when you create output JPGs. The Batch Processs is best explained by trying it. Select two or more files, then select the Batch Process in the Files menu.
